Polishing exterior
Old Aug 11, 2019 | 09:52 AM
frank barone's Avatar
Default Polishing exterior
New owner with a my16 f type s, panoranic glass roof. I have a professional car detailer scheduled to polish my jaguar. It will be washed by me and then he will clean, clay, apply polish and sealer. How does he, me in the future, apply polish to the glass roof area, or this area avoided at all costs. What does one use to clean glass roof?
I rely on your expertise to guide me, thanks
frank my16 f type s panoramic roof
Old Aug 11, 2019 | 10:55 AM
sov211's Avatar
You treat the roof area in exactly the same way that you treat the paint: a good carnauba wax.
Old Aug 11, 2019 | 11:00 AM
Ok thanks for your quick response, then am I to assume that a professional should only clay bar the painted areas and leave the roof alone
Old Aug 11, 2019 | 05:22 PM
sov211's Avatar
Clay barring the roof will do no damage and will prepare the surface for wax...a good wax like Victoria Wax (not a wax with abrasive in it -those are call " cleaner waxes" ).
Old Aug 11, 2019 | 05:32 PM
Thank you, as a new owner who never had a glass roof I wanted to be very careful with clay bar and polish/sealant
Frank my16 f type s coupe
Old Aug 11, 2019 | 06:09 PM
jaguny's Avatar
I had mine ceramic coated with the rest of the car. I wash and then use GLIPTONE GLASS CLEANER.
Old Aug 11, 2019 | 07:17 PM
BruceTheQuail's Avatar
I cleaned mine with rainex paste and then put the rainex stuff on it, water flies off.
Old Aug 11, 2019 | 07:55 PM
Unhingd's Avatar
Do you really drive in rainstorms looking through the roof?
Old Aug 11, 2019 | 09:27 PM
Me driving with one eye on the road and the other watching water slide off my rainexed glass
I actually do! It is really pretty looking through the roof sometimes, we get hot air balloons overhead on my way into work.
But I also keep one eye on the road...
Jaggyx's Avatar
If you want the best possible finish on glass, you can clay bar it, use CarPro Eraser, and then a ceramic coating Overkill for most people, but if you're into detailing, the only way to go. After the ceramic coating, maintain with P&S Bead Maker.
Old Aug 11, 2019 | 09:37 PM
Unhingd's Avatar
I too will look through the roof, primarily to keep an eye out for bear in the air, but they typically don’t fly in rainy IFR (low visibility) conditions.
Old Aug 12, 2019 | 01:22 AM
lizzardo's Avatar
The roof is glass. I treat it like other glass, not like paint. I don't use wax on my windshield, so would not use it on the roof. I got some glass coat stuff, similar to Rain-X, that is from the same manufacturer as the stuff I use on my rims. Too tired to look it up tonight. I'd have to go out to the garage and dig through my detailing bins.
Old Aug 12, 2019 | 11:10 AM
sov211's Avatar
Right. It is glass, so I treat it just as I do the other glass on the car, especially the windshield - which means using carnauba wax on it. Water beads right off, no smearing, wipers work just fine when needed (which is rarely) and the glass is crystal clear. No need for an expensive substitute.
Old Aug 12, 2019 | 11:20 AM
lizzardo's Avatar
Interesting. I treat it as glass and don't use carnauba, you treat it as glass and do.
Old Aug 12, 2019 | 11:29 AM
Jaggyx's Avatar
Carnauba isn't going to hurt glass in anyway so waxing is perfectly fine. It will attract dust though.
Edit: I did a bit of testing one day to see how much more dust a wax attracts vs. a coating. Take a look below at the red box. You can see a pretty clear indication of where the wax stops and where the coating starts.
Old Aug 12, 2019 | 01:31 PM
lizzardo's Avatar
I wasn't suggesting harm to the glass, just quality of results. If anyone is happy with what they're doing, I suggest they keep at it. The high-tech glass coating was not cheap, but the amount used is quite small. I got a pack of it and the matching wheel coating, and based on my purchase date and how much I have left, I'd say it's a few dollars per year. I think the price has gone up since 2015, but won't need to replace it until 2023 or so.
Old Aug 12, 2019 | 02:33 PM
Unhingd's Avatar
Anyone who got a bottle of the Prep’N’Polish on one of the Lobster or Blueberry Runs should try it on the glass. Designed to work on Monitors and touchscreen displays as well. Minimizes finger smudging.
Old Aug 12, 2019 | 06:25 PM
jaguny's Avatar
I happily use it on everything but the windshield and roof glass. I will try it though. Thanks againn for the gift!
Old Aug 12, 2019 | 08:27 PM
RickyJay52's Avatar
THE best detailing spray I have ever used. Period.
Old Aug 13, 2019 | 06:36 AM
DJS's Avatar
DJS
It’s also a non-dairy floor wax...
ultra88
Jun 15, 2022 04:14 AM
Andrew Diment
May 15, 2019 12:05 AM
malc4d
Dec 11, 2014 08:45 PM
jleuz1
Oct 2, 2014 07:17 PM
vincent661983
Jun 28, 2012 12:32 PM
