pothole
Old Jun 1, 2016 | 05:56 PM
jamiejag's Avatar
Default pothole
hit a pothole looked underneath behind front wheel and what looks like rubber and coating which seems to have come away slightly,anyone any idea what this rubber compound is please?
Old Jun 1, 2016 | 10:20 PM
Nati's Avatar
gonna have to do better than that, chief
Old Jun 1, 2016 | 11:21 PM
Foosh's Avatar
Yes, take two aspirin and call Dr. Nati in the morning. :-)
Old Jun 2, 2016 | 02:02 AM
jamiejag's Avatar
Sorry Doc ! Its behind groin wheel near jacking point like a teflon/plastic coating that seems to be coming off see pics
Old Jun 2, 2016 | 02:05 AM
jamiejag's Avatar
behind front wheel! auto spell error
Old Jun 2, 2016 | 03:11 AM
Uk2usa's Avatar
This is a rubberized undercoating, it's basically there to protect from salt water, small stones and deaden sound etc. Google 3M rubberized undercoating, it comes in a spray can and is very easy to use and doesn't drip. Just peel off loose coating and spray it on.
You can give it multiple coats if you want.
Old Jun 2, 2016 | 10:37 AM
jamiejag's Avatar
Many thanks for your assistance.
Old Jun 2, 2016 | 12:54 PM
F-typical's Avatar
Given that this pothole was big and deep enough to dent the chassis, getting the wheel checked for dents/cracks, and having the alignment looked at might be a good idea.
Old Jun 2, 2016 | 04:57 PM
jamiejag's Avatar
Thanks checked chassis no dents and fine,steering and wheel all good.
Old Jun 2, 2016 | 07:18 PM
Unhingd's Avatar
Certainly looks like a dent (and crease) in the floor pan. I suggest you have a Jag approved body shop look at it. They can also repair the undercoat.
Old Jun 3, 2016 | 12:50 AM
jamiejag's Avatar
where exactly do you see the dent/crease?? The floor pan is not even in photo .The photo is of where the rubber compound is by jacking points which is uneven .It went in yesterday and was checked and could not find anything.
Old Jun 3, 2016 | 08:47 AM
Foosh's Avatar
I don't think that's a "dent." Obviously the undercoating is very uneven, and what looks like a crease appears to be stamped into the aluminum.
Old Jun 3, 2016 | 08:49 AM
jamiejag's Avatar
I cannot see a crease?
Old Jun 3, 2016 | 09:08 AM
Foosh's Avatar
It's probably misleading to refer to it as a "crease." I'm looking at the indented lines in the left of your photos above, first and third are horizontal and middle one is nearly vertical.
Old Jun 3, 2016 | 03:46 PM
F-typical's Avatar
Well, maybe it is just a mark in the underseal.
But, that still means the chassis hit the ground.
Were you driving off-road, or are local roads really that "character-building"???
Amelorn
Jun 11, 2025 01:41 PM
TPBachur
Jul 30, 2016 07:33 AM
Louenigma
Apr 25, 2016 09:18 PM
plums
Apr 8, 2016 05:40 PM
kenatofc
Apr 3, 2016 10:42 AM
