Prevent auto downshift in dynamic mode
Old Jul 20, 2014 | 09:14 AM
user 467478's Avatar
Banned
Default Prevent auto downshift in dynamic mode
Is there a way to prevent the car from downshifting automatically in dynamic mode?
I find sometimes it doesn't downshift (manually) as quickly as I'd like it to ...and it feels like it's trying to optimize and potentially in some cases override my feedback on the downshift (which I don't want it to do!).
Thanks!
Old Jul 20, 2014 | 02:26 PM
DJS's Avatar
DJS
Push the gear selector to the left to select Sport Mode - in Dynamic and Sport, it won't shift automatically at all, except to keep the car from stalling.
Old Jul 20, 2014 | 02:46 PM
enderle's Avatar
Default Think you have to use the paddles
I drive mine in sport and dynamic a lot and it still shifts automatically until you use the paddles once then it goes manual for about 90 seconds (extended each time you use the paddles). I'm not sure on the 90 seconds part but think the timing is in the manual.
Old Jul 20, 2014 | 10:39 PM
IronMike's Avatar
This post appears to explain the many personalities of the F-Type transmission...
Originally Posted by mparsons
Sport mode only changes the shift logic (holds gears to higher rpm before shifting, stays in a lower gear whenever possible).
Dynamic mode changes throttle response, steering weight, suspension stiffness, and gives faster gear shifts.
These two modes also change how you can use the paddles.
In drive+manual: allows for manual shifts using paddles, but times out back to automatic after 60 seconds. Also will revert back to automatic if you are bouncing off the rev limiter without shifting.
In sport+manual: allows for manual shifts and does NOT revert back to automatic after 60 seconds. However, this mode will still revert back to automatic if you are bouncing off the rev limiter without shifting.
In sport+dynamic+manual: allows for manual shifts and does NOT revert back to automatic after 60 seconds, and will NOT revert back to automatic if you are bouncing off the rev limiter without shifting. This is a true manual mode with no override.
Love hearing your impressions of the F-Type. Especially considering the caliber of cars you've previously owned!!
Old Jul 20, 2014 | 10:49 PM
swajames's Avatar
In "S", it will hold any manually the gear you selecte, won't upshift at redline and it will only downshift if you are in too high a gear when coming to a stop (to prevent a stall as another poster said). Otherwise, it will hold the gear you select until you choose another.
Will P
Sep 19, 2018 08:36 AM
Jagged-X
Sep 24, 2015 05:08 PM
Ekki
Sep 21, 2015 12:09 PM
Clamdigger
Sep 12, 2015 03:43 PM
