A question on disabling start-stop button.
Old Dec 3, 2024 | 06:42 AM
Kypros's Avatar
Default A question on disabling start-stop button.
Dear all,
I've been reading the various threads about disabling start-stop.
I rather like the approach of disconnecting the small battery in the boot.
Does this affect any other functions of the car? or is its sole purpose only for the start-stop operation.
Thank you for any answers.
Old Dec 3, 2024 | 07:29 AM
DJS's Avatar
DJS
There was only a 2nd battery on I think the first 2-3 model years. After that they went with an ultra-capacitor, I believe. The 2nd battery (if you have it) is easy to disconnect, but it took me quite a while to figure out how to remove it.
It does nothing other than support start/stop. On my car, the ECO button lights up when I start the car, then turns off after 5-10 seconds, as start/stop isn’t available. No messages or codes.
Old Dec 3, 2024 | 07:48 AM
Kypros's Avatar
Thank you for your answer,
my car is a 2016 model year and I haven't looked to find the 2nd battery assuming there is one.
Old Dec 3, 2024 | 08:09 AM
DJS's Avatar
DJS
It’s under the trunk liner, near the right taillight.
Old Dec 3, 2024 | 08:30 AM
DJS's Avatar
DJS
Took a while to find these, from when I removed the battery in 2021…
From the front of the trunk, looking towards back right corner of the car
From the front of the trunk, looking towards the back left corner of the car from this perspective
Looking down at the battery
Old Dec 3, 2024 | 08:33 AM
Kypros's Avatar
Thank you for the pictures, they do help.
Old Dec 3, 2024 | 08:59 AM
uncheel's Avatar
Also, if you have a convertible, you can get a SmartTop module that will allow you to systematically turn off start/stop, along with several other functions, including setting the exhaust and enabling the fob to lock/unlock the doors, open/close windows and top)
Old Dec 3, 2024 | 09:01 AM
Kypros's Avatar
Thank you, my car is a coupe.
Old Dec 3, 2024 | 10:08 AM
Robtrt8's Avatar
My 2016 didn’t have a second battery.
Old Dec 3, 2024 | 12:15 PM
Kypros's Avatar
Thank you, won't that affect anything else?
Old Dec 3, 2024 | 12:18 PM
Robtrt8's Avatar
The Start/Stop disable light on the instrument panel stays on. Otherwise, no ill effects.
Old Dec 3, 2024 | 12:20 PM
Kypros's Avatar
Thank you, I'll go and do it. You have solved a big problem for me,
Old Dec 3, 2024 | 12:26 PM
Robtrt8's Avatar
The module is in the trunk space under all the trim and compartment covers. Sitting right on the bottom of the trunk floor. I think this covers post dual battery cars up to the facelift cars.
Old Dec 3, 2024 | 12:50 PM
Kypros's Avatar
I've done it, I switched on the ignition without starting the engine but the start-stop disable light didn't come on, also the disable button was lit all the time.
Old Dec 3, 2024 | 12:56 PM
Robtrt8's Avatar
Need to complete the cycle. Start/Stop wasn't available for a couple minutes after startup anyways. After the motor is running it determines if the car has enough volts available to enable Start/Stop. It will decide it doesn't because you've unplugged the module and it doesn't "see" the voltage. Same as having a car with an older battery with less capacity.
Old Dec 3, 2024 | 12:58 PM
Kypros's Avatar
Thank you, now I have 1 less thing to worry about.
Old Dec 3, 2024 | 01:25 PM
eeeeek's Avatar
I unplugged mine in the first week of ownership. I've never seen a light unless I've actually pushed the button as a 'what if' test.
In the US, 2016 and up did not have the second battery.
Old Dec 3, 2024 | 01:45 PM
Kypros's Avatar
Problem solved, thank you all. This is the greatest forum ever.
Old Dec 5, 2024 | 09:46 PM
diablo2112's Avatar
There is one use for auto start/stop that has some value: it only activates with sufficient battery charge. I kept mine active for this reason. If auto start/stop is active, then I know I don't need to put the battery on my maintainer. I do a bit of short trips around town, and occasionally have to top-up the battery. Auto start/stop is a very nice way to determine when the battery needs to be charged.
Old Dec 5, 2024 | 10:34 PM
Kypros's Avatar
As I don't use the car regularly, It's always connected to the Noco maintainer. when garaged. I'm under the impression the Noco maintains the battery to last longer.
