A question on disabling start-stop button.
Old Dec 6, 2024 | 04:59 AM
Robtrt8's Avatar
That’s my thinking as well. Also, the Jag’s are not happy with a partial charge and electrical gremlins can come out to play. I’d rather not let them see the light of day.
Old Dec 6, 2024 | 05:22 AM
DMeister's Avatar
Definitely on my list of things to disable on my 2024. Can’t stand this feature. Why they didn’t make this thing configurable on/off is beyond me.
Old Dec 6, 2024 | 05:23 AM
Kypros's Avatar
I guess it was the law.
Old Dec 6, 2024 | 05:26 AM
DMeister's Avatar
Or as a way to ensure the sale of more starter units ;-o
Old Dec 6, 2024 | 05:31 AM
Kypros's Avatar
I believe that when manufacturers introduced the start-stop feature, they upgraded the starter, the battery and the alternator. If we don't use the start-stop, all these components will last much longer.
Old Dec 6, 2024 | 09:46 AM
Therock88's Avatar
Here is a little helpful info I put together a while back, when I did mine 👍
DC
Old Dec 6, 2024 | 09:50 AM
scm's Avatar
scm
There's a video on Youtube explaining what had to be changed to support stop/start - quite surprising as, among other things, it involves revising the engine timing so it starts from where it had stopped rather than needing to find a timing mark to sync things as in a cold start. Quite fascinating. But the battery and starter aren't that stressed starting a hot engine, so not sure about lasting "much longer" - my battery is coming up to 8 years now (hope that hasn't jinxed it).
Old Dec 6, 2024 | 10:10 AM
  #28
Evoex's Avatar
Original battery just went on my 2016.
Old Dec 6, 2024 | 12:48 PM
WayneB's Avatar
I always hated the Start Stop on my car and it almost cause a couple of accidents. A couple of times I would come to a stop sign and come to a complete stop for about .3 sec. and the car would start its shut down sequence just as I stepped on the gas petal to beat traffic and the car would roll forward a little ways and shut down and not start. I would have to manually shut the car off then restart it while I'm sitting half way into an intersection. It's a good thing I didn't get T-Boned. After a couple time of that I disabled the Start Stop.
It seemed that if I stepped on the gas too soon while the car was starting its shut down sequence it would get confused and just shut down and die.
Old Dec 6, 2024 | 01:48 PM
  #30
Kypros's Avatar
Beautiful illustrations and explanations.
Old Dec 6, 2024 | 02:40 PM
  #31
sov211's Avatar
DC
This good information applies to the later cars which do not have a small, separate battery for the Stop/start function. The solution for the cars with a second battery is equally simple. You just remove the negative lead (or both leads) from the small battery, wrap a bit of foam around it and tuck it away. Done. And if you remove the battery itself you save a bit if weight!
To repeat what has beeen stated many times: disabling the Stop/start connections does not affect any other system.
Old Dec 6, 2024 | 08:33 PM
  #32
Thunder Dump's Avatar
Originally Posted by uncheel
Also, if you have a convertible, you can get a SmartTop module that will allow you to systematically turn off start/stop, along with several other functions, including setting the exhaust and enabling the fob to lock/unlock the doors, open/close windows and top)
This. I cannot stress enough how awesome (and safe) SmartTop is and should be mandatory if you have a convertible. It not only makes top operation possible from the remote, but it can disable the stop/start for you automatically on every start up.
Laika
Jul 26, 2023 06:56 PM
jgwjr
Dec 15, 2022 07:27 PM
Jonty Angle
Jan 26, 2021 01:37 PM
OWRltd
Dec 17, 2014 07:52 AM
