Quoted 52k to replace carbon ceramic brakes, any aftermarket options?
Old Jan 1, 2023 | 05:03 PM
cujet's Avatar
On the higher end Jet Aircraft, carbon/carbon brakes are the norm. Our various Gulfstream aircraft all use them. The brake shop can overhaul them, but the rotors and stators (stators are like full circle pads) wear as a matched set. That's why one cannot replace one stator that has some minor fault. The entire stack must be replaced. About $80K.
HOWEVER, it is possible to machine both components flat and have a newly matched set again with zero performance loss, "IF" there is sufficient material to remain well within the working wear limits.
Also of note, the steel brakes with sintered metallic stators work just as well. But they only work once, such as 1 high speed aborted takeoff, before they exceed temperature limits and performance suffers. That's fine really, as the Carbon ones will catch fire on the second aborted takeoff.
If your brakes are truly bad, I'd switch to some high end racing steel brakes and go on my way.
Old May 13, 2023 | 11:03 AM
gwng8's Avatar
i cheked at a local Jag dealer in Canada:
$3000 per axle for pads
$10000 per rotor
So yeah there has to be better options
Old May 13, 2023 | 12:01 PM
jcb-memphis's Avatar
Convert to steel...get the girodiscs from Stuart at VAP and work with him on calipers/adaption. I suspect this could be a huge opportunity for VAP to come up with a "conversion kit" for those with ceramic systems. Guessing 5-8k total.....so a huge benefit to owners too...not cheap, but not 40-55k either.
Note to self - continue to avoid ceramic brakes like the plague unless I get a driver contract and someone else is paying for the car....
Old May 13, 2023 | 12:42 PM
Pupilbone's Avatar
Originally Posted by Stevenl4878
Hi all,
Located in Canada and was quoted $52,000 to replace pads and rotors on the F Type SVR with carbon ceramics. That is way too much for me to stomach, so I’d like to ask:
1. Am I able to swap to the steel “super performance” brakes?
2. are there any aftermarket brake options that will work on the CCBs? I looked around but I can only find ones for the steels.
Thank you!
OK - Wow.
Old May 14, 2023 | 03:04 PM
jaguny's Avatar
Hi all,
Thank you!
How many miles on those brakes?
Old May 14, 2023 | 09:29 PM
BritCars's Avatar
And why do they need replacing?
Old May 15, 2023 | 05:29 PM
usgpru27's Avatar
As noted above. Have them weighed. That is why the weight is on them. DO NOT let the dealer weigh them unless they have experience. Send them (or one front one rear) to an exotics shop where they do it all the time. If the car is not tracked I very much doubt you need them. Pads yes and should be lower labor. A caliper change is about a 10 minute job. You can get rotors for $4200 each I believe.
Old May 16, 2023 | 12:51 PM
  #28
F-type-r-2022's Avatar
Hi all,
Thank you!
Thats $52k in CANADIAN dollars
Old May 16, 2023 | 09:47 PM
usgpru27's Avatar
Rotors and pads about 26K. 2K labor USD. I strongly recommend getting those rotors weighed.
Old May 23, 2023 | 05:06 PM
  #30
Jaaaaag's Avatar
Man am I glad that I went for the R over the SVR then. I recently picked up my 2020 R and was debating between that and a 2019 SVR with CCB. The main reason I opted for R was due to a $20K accident claim on the SVR Carfax but damn I dodged a bullet insofar as CCB are concerned.
Diorwing
Oct 7, 2022 01:50 PM
Ubad2
Apr 6, 2021 08:56 AM
mws
Aug 22, 2020 03:05 PM
sgvkirbster
May 24, 2018 07:51 PM
Vette Guy
Oct 18, 2014 11:38 AM
