Rear Wheel Bearing
Old Nov 30, 2022 | 09:13 AM
mcphill's Avatar
Default Rear Wheel Bearing
I am getting a good bit of noise from the driver side rear, sounds like a rear wheel bearing to me. Anyone replaced or had an issue with theirs?
Old Nov 30, 2022 | 09:30 AM
mcphill's Avatar
Found this for the X-Type, likely pretty similar.
Old Nov 30, 2022 | 02:58 PM
mcphill's Avatar
Well, digging in a bit more it appears the rear is a bit different than that video, but also just the bearing itself is replaceable. Will have to look in to this further...
Old Apr 13, 2023 | 11:27 AM
Cwis's Avatar
I'm also currently hearing a bit of howling from the rear that sounds like the wheel bearings. Did you manage to only replace the bearings, or did you replace the whole wheel hub?
Also, where did you get your parts from?
Old Apr 13, 2023 | 11:37 AM
mcphill's Avatar
I have no idea what I did! Not making any noise, and I don't recall doing the bearing...
Dmcr
Dec 15, 2021 03:29 AM
Kopi
Jan 4, 2018 09:54 AM
WinterJag
Dec 1, 2016 03:42 PM
TN8Shooter
Jun 5, 2012 12:18 PM
walkman1
Nov 16, 2010 11:47 AM
