Red Battery light after visiting dealer
Old Sep 15, 2020 | 08:30 PM
Mbourne's Avatar
Originally Posted by Unhingd
Sure. Try this: https://ezbatteryreconditioning.com/...tioning.top%2F
I also have a bridge for sale.
That video is hilarious. It never ends...........................
Old Sep 15, 2020 | 09:06 PM
OzXFR's Avatar
I just watched it and gave up after about 20 minutes, it just goes around and around in circles and I am sure it never even attempts to explain the "secret method".
Old Sep 16, 2020 | 04:46 AM
scm's Avatar
scm
... the only thing we did learn that was not so great was that there was some dried coolant on the water pump. Not a lot but it appears that the pump has a very small and slow leak.
That's a common issue so it's good that you've spotted it early. I had one go at 13,000 miles (after 6 years) in a 2010 XKR.
Old Sep 16, 2020 | 05:53 AM
peppersam740's Avatar
You have to spend the 47.00 to find out. I wonder how many people got suckered ?
Old Sep 16, 2020 | 06:55 AM
DJS's Avatar
DJS
Marko, I changed mine after 7 years, as I didn’t figure it would last much longer. Past experience has been when they fail, it’s quick - seems to be OK one day, won’t start the car or hold a charge the next. Once I learned that, I started swapping batteries every 5-6 years. Of course, those weren’t $200+ batteries...
Old Sep 16, 2020 | 08:07 AM
Carbuff2's Avatar
Let's start a rumour that Lance is the spokesman! That's him in the blue shirt, right?
If you need me, be patient. I'll be at the local golf course trying to score free golf cart batteries....
Old Sep 16, 2020 | 09:23 AM
Unhingd's Avatar
I smell a libel suit brewing!
Old Sep 16, 2020 | 11:26 AM
  #28
Mbourne's Avatar
The costs of this service, pad replacement, brake flush and fluid replacement and new battery all came to $525. I bought the pads directly from porterfield for $118 about three months ago so all in i spent $643 for this. Did not use the dealer who was going to charge me $1100 for the brakes alone and found a great Eurocar shop with two gold certified Jag techs who I plan to take the car to all the time now since the warranty is over.
Old Sep 16, 2020 | 01:59 PM
Good place to score. Need to tell that guy in Australia.
Old Sep 16, 2020 | 04:12 PM
  #30
DJS's Avatar
DJS
Excellent. Will be interested to hear what you think of the Porterfields. My brakes are probably due soon.
Old Sep 16, 2020 | 07:27 PM
  #31
Mbourne's Avatar
So far they are great. No real extra bedding required and I don’t smell them at all. Now I have not yet done a serious stopping but today I took it out on some roads where I need to lay into them a little more and they had good bite and didn’t fade at all. Initially the pedal travel seemed a little more than with the OEM pads but I’m just not sure that wasn’t my imagination based on some of the experiences of others. They seemed to have good bite early and even better bite mid pedal push. I’m going to give them another Hundred miles or so and then do some real serious braking to check them without glazing them. So far so good.
Old Sep 16, 2020 | 08:36 PM
  #32
Unhingd's Avatar
The Porterfields certainly work well on the Wortecs. Also much less dust than the OEMs.
Old Sep 16, 2020 | 09:56 PM
  #33
Awd's Avatar
Awd
Old Sep 17, 2020 | 07:59 AM
  #34
Vindi's Avatar
Hi All, first off - love the Battery Reconditioning vid - very funny.
Took my car to a JLR dealer this week for its first PA state inspection and a service, about 120 mile round trip. All went well, pointed out a couple of things that have been referred to on this forum - passenger chrome window trim lifting next to door, rear parcel shelf falls off its posts - fixed with tie wraps. They ordered replacement parts under warrantee - fantastic I didn't have to argue or haggle.
Next day opened up the car and met the Low Battery - Please start the engine message. No way that battery is dead - just drove 120 miles I thought. Tried to call the dealer but went to voicemail. Jumped on the forum and found all the discussions about the Battery Low warning - undid the pos terminal of the battery for 30 secs (had to manually open and close the rear hatch) but after reconnecting the battery it worked again. Went for a lovely drive. Got back turned it off and went back half hour later - all is well, no warnings. Checked again today - no warnings.
So thank you fellow F Type owners - easy fix indeed. I wonder why jag have never fixed the OBD root cause of this issue - oh well.
*Note to those to the non electrical savvy here - its makes no difference which terminal you disconnect from a battery - trust me I am and electronic design engineer
FullChat
Dec 16, 2019 01:22 AM
carzaddict
Jan 31, 2017 03:19 PM
dennyhle
May 25, 2016 09:21 PM
Jffcurt
Jun 29, 2014 09:58 AM
Sukki
Dec 2, 2013 05:40 AM
