replacement hardware
Old Mar 10, 2024 | 10:16 AM
Zen Beer's Avatar
Default replacement hardware
Is there a guide, table, or manual that lists replacement hardware information?
Example when reinstalling engine, transmission, driveline all the bolts are torque to yield and per the manual should be replaced. Unfortunately the workshop manual doesn't list part numbers to replace them with. I have been able to find a few online, but not easily or reliably.
Old Mar 10, 2024 | 10:46 AM
clubairth1's Avatar
Community Influencer
Jaguar breaks their documents up into the JTIS. Which is the work shop manual. As you found out it has no part numbers.
Next they issued the JEPC-This is the parts manual with exploded diagrams and part numbers. It's the same thing the Jaguar parts guy uses.
BUT the last version was released publically sometime around 2018 so after that you must rely on the on-line parts system from Jaguar dealers.
You should be able to find the hardware using the factory parts sites but it will take some time as I find the JEPC/J-Part has much more detailed information.
This is a big Jaguar on-line seller so makes some searches on their site and see if you can find what you need.
Jaguar Factory On-Line Parts
If your interested I find it worthwhile to get and install both the JTIS and the JEPC. They are both free and on this forum. Easy to find with a few searches.
Old Mar 10, 2024 | 10:49 AM
Zen Beer's Avatar
Thanks, hadn't installed JTIS or LPEC yet. It is on my todo list.
Appreciate the guidance
Old Mar 10, 2024 | 10:55 AM
clubairth1's Avatar
No problem and I wish it was easier too!
We had a big problem when Flash Player was discontinued and we had no way to run JEPC anymore. Well we could run it but no diagrams!
Finally a forum member named Steve helped us out and wrote JPART which he gave to us free to use. It still requires that you download and install JEPC first but his instructions are very good!
Install JPART
As has been posted many times all the documentation is difficult and confusing to use.
Old Mar 10, 2024 | 03:53 PM
Rondog's Avatar
Clubarith1: Appreciate the download link for the JPART. Searched the threads for JEPC but nothing comes up. Noting you have to have this installed before the JPART. Also looked under the helpful hints at the beginning of this section and no luck. Can you post the link to the JEPC??
Old Mar 10, 2024 | 08:01 PM
Zen Beer's Avatar
Old Mar 11, 2024 | 06:57 AM
DJS's Avatar
DJS
FYI, I copied the JEPC archive to my Dropbox…
https://www.dropbox.com/scl/fi/h24wk...rxabga5bj&dl=0
Old Mar 11, 2024 | 09:19 AM
clubairth1's Avatar
Thanks again to DJS! Another great benefit of this forum.
memento84
Nov 26, 2021 12:37 PM
pcolapacker
Jun 6, 2021 07:40 AM
a6kmita
Apr 26, 2017 09:56 AM
dagarair
Mar 22, 2015 09:42 AM
