Rough starts
Old Apr 14, 2018 | 10:47 AM
Itismejoshy's Avatar
Default Rough starts
Have any of you had an issue with rough/misfire startin when cold? Before I call my server manager (who has been amazing) and drop it back off. It has never done this before I just had major engine work done under warranty, and drove it to keywest from MA with zero issues, other then the AC not blowing cold, dropped it off they took care of it, now the last 2 cold starts after sitting, it will fire right up and idle rough then stall. I can keep it running with alittle peddle and eventually it will gather itself and run fine. Any ideas before i drop it back off again (3hrs of driving)?
15 V8S
Old Apr 14, 2018 | 03:13 PM
DJS's Avatar
DJS
Bad gas?
Old Apr 14, 2018 | 04:05 PM
Could be...or maybe the obdii issue, they updated my software.. But starter doesn't sound slow.
Originally Posted by DJS
Bad gas?
Old Apr 14, 2018 | 05:51 PM
RGPV6S's Avatar
Bad gas?
Water in the gas? Might try some dry gas additive.
Old Apr 15, 2018 | 10:18 AM
Update: I filled it up with new fuel, it started fine. I pulled out and the dash freaked out (also a first). So my first thought was loose terminal on the battery, it was very loose. So I tighten it and it fired right up and has ran good so far. 🤞
Old Apr 15, 2018 | 01:30 PM
Unhingd's Avatar
That'll do it!
Old Apr 18, 2018 | 08:18 AM
Update: better but still something isn't right, i will look at the live data this week and see if i can determine anything.
Old Apr 24, 2018 | 11:49 AM
CEL finally showed up:
P2180 - System Too Rich Off Idle Bank 2
P2178 - System Too Rich Off Idle Bank 1
P2190 - System Too Rich at Idle Bank 2
p2188 - System Too Rich Off Idle Bank 1
once warm, runs mint. Reset codes 2x come back after a few starts. 3 tanks of fuel, bottle of dry gas in the 2nd tank.
Any ideas?
Old Apr 24, 2018 | 11:57 AM
DJS's Avatar
DJS
Search this for the codes - it describes the various faults that could cause them...
https://www.dropbox.com/s/1ek33ux7tf...guide.pdf?dl=0
Old Apr 24, 2018 | 12:26 PM
Unhingd's Avatar
Any ideas?
I would just be guessing. Plugged air filter? Bad MAF sensor?
Time to bring in the pros.
Old Apr 24, 2018 | 12:57 PM
Thanks for this!!
Old Apr 24, 2018 | 01:00 PM
Thinking its MAF or injector related, being that its on both sides i would lean towards MAF, but i dunno. im just going to drop it off at this point. thanks for the insights.
Old Apr 24, 2018 | 05:41 PM
OzXFR's Avatar
If it's on both sides then it's unlikely to be the MAF sensors, as there are two of them one on each intake tract and they would both have to fail in the exact same way at the exact same time.
Old Apr 24, 2018 | 06:25 PM
Unhingd's Avatar
I believe there’s one in the intake tube leading to the SC. I got a similar set of codes when I pulled off the intake crossover tube. Fabulous SC whine, though.
Old Apr 24, 2018 | 06:47 PM
OzXFR's Avatar
There are definitely two MAF sensors, one in each intake tube, see this post: https://www.jaguarforums.com/forum/f...8/#post1878841
Down at the bottom of parts 5 and 6, in the "resonator" tubes and just above the air boxes. I am 99% sure there is no other MAF sensor anywhere, maybe you are thinking of the MAP sensor?
Also, that pic confirms there are three L shaped resonators on the upper part of the intake tract, one each on parts 7, 8 and 9.
Old Apr 24, 2018 | 07:16 PM
Unhingd's Avatar
I knew I had seen at least one MAF sensor on one side. It makes sense that there would’ve been 2, one in each side. For the OP, is it possible you have a loose connection in one of the intake tubes?
Ah, but that won’t account for the rough idle.
Old Apr 24, 2018 | 07:40 PM
OzXFR's Avatar
I would be looking at the intake tube right at the end, the Y piece that fits around the throttle body opening. It may be cracked or split underneath letting unmetered air in, this has happened to a few high-mileage XFR and XF SCs.
Old Apr 24, 2018 | 07:53 PM
​​​​​​....🤔 will take a look!
Old Apr 25, 2018 | 08:26 AM
DJS's Avatar
DJS
Wouldn't that produce a lean condition, not rich?
Old Apr 25, 2018 | 08:53 AM
Unhingd's Avatar
yes, just a bit lean, but since all the air is not routed across the MAF it will lead to a “too little air” warning.
