Seat Belt chafing?
Old Jul 22, 2020 | 06:52 PM
3 Speeds's Avatar
Default Seat Belt chafing?
My seat belt cuts across my neck on the side and is really uncomfortable. Looking at the strap that holds it to the seat back I can see that when I'm wearing it it rides up towards the top of the strap, and into my neck.
So I'm thinking there is some way I can hold it down in the lower section of the strap which keeps it off my neck. Has anybody else had this problem, and maybe a solution? I'm thinking of some kind of "guide" that can keep the belt down low in the strap.
Thoughts? Comments? Ideas? Suggestions?
Thanks!
Old Jul 22, 2020 | 07:24 PM
OzXFR's Avatar
Thanks!
I and a few others had the exact same problem and there is a thread and/or some posts on it around here somewhere (but I'm too lazy to search for it/them!).
What works for me is to tie a length of Velcro strip tightly over the midpoint of the seat belt retaining strap, leaving just enough room for the seat belt to extend and retract smoothly.
I bought a long roll of Velcro (in red to match my seat) 1 cm wide, see here for example: https://www.ebay.com.au/itm/Hook-and...cAAOSw~ttenzvj
The seat belt stays in place fairly well but eventually the Velcro strip wears out so I simply replace it with a fresh piece cut from the roll, and I have several metres of roll still.
My first solution which worked well was a large zip tie but being black it stood out against the red seat and I was a little worried about it damaging the seat so I switched to Velcro instead.
Here's a pic of the zip tie in place:
Old Jul 22, 2020 | 07:25 PM
Therock88's Avatar
Thanks!
I am with you....cuts right into my clavicle and side of my neck. Not sure if it will help, but I recently ordered some pads to see if it helps? They wrap around the seat belts. We will see.
DC
Old Jul 22, 2020 | 07:35 PM
3 Speeds's Avatar
Exactly what I was thinking, but I didn't think about the color. I'll try the zip tie, looks like a good alternative.
Thanks!
Old Jul 22, 2020 | 07:44 PM
Mbourne's Avatar
Mine cut across me in the same way. If I’m wearing a shirt with a collar I tend to adjust it so it folds over the belt which cuts down on the chaffing but I like the pad idea but what I would really like to do is flip the strap over and snap it below rather than on top.
Old Jul 22, 2020 | 07:51 PM
OzXFR's Avatar
If I remember correctly I first tried the seat belt "comforter" method, like those shown by Rocky (I already had a pair), but it didn't work at all.
Maybe I had the wrong type and/or I didn't position it correctly, but it did absolutely nothing to stop the seat belt riding up and rubbing my neck.
Old Jul 22, 2020 | 08:23 PM
OzXFR's Avatar
Found the old thread: https://www.jaguarforums.com/forum/f...y-neck-188654/
Old Jul 22, 2020 | 09:29 PM
Therock88's Avatar
Well....That's not good! They did not cost much, so if they do not work, I will use them as a rag or something. I may try adjusting the seat, but do no think that mows me relative to the belt?
Many cars are adjustable and i put them on the highest setting and they are fine...but no way on this one. I am 6'4"+ and about 230 lbs....So I am snug in there!
Will see if they do any good. Thanks.
DC
Old Jul 22, 2020 | 09:38 PM
madmax1911's Avatar
Instead of wrapping the Velcro around the outside, what about attaching (adhesive backed) to the underside of the retaining strap and the edge of the seat ? If the Velcro was the same width it would be invisible and in a crash would just release, allowing the belt to travel in the retaining strap as designed.
This hadn't really bothered me much but the SO has complained a couple times about it. Think I will try it and see how she likes it and report back.
scottatl
Jul 21, 2020 01:42 PM
marvin.d.miller
May 7, 2015 01:19 PM
yardpro
Mar 19, 2011 05:17 PM
Brian2000XKR
Dec 18, 2009 05:20 PM
