Service required light
Upon start up today I got a service required in 3100 kms
The dealer just did the service at around 30k kms a few months ago just before I bought the 2016 F Type R with 32k kms
I now have 34k kms
Is this an oil /filter change service ?
I thought it was required 16k miles or annually according to the maintenance schedule.
Is this maintenance indicator using some sort of an algorithm like other cars like Honda where the service is dependent on variable things such as how hard you drive, temperature etc.
I now have 34k kms
Common annoyance when the dealer forgets to reset the maintenance indicator.
To reset:
1) Set ignition on
2) Open hood
3) Open driver's door
4) Fully depress both accelerator and brake pedals for a few seconds
5) Turn off ignition
If the message still appears, try again.
To reset:
1) Set ignition on
2) Open hood
Ok I will give it a try.
So there isn't a random algorithm like Honda has that varies the length of time or mileage before a service is required.
Thank you for your help.
Just a newbie with my new Jag but loving the car.
Never had so many people stop to look at this beautiful machine.
My dealer told me to hold them both depressed for 30 seconds!
It's both time and mileage based - I don't believe there is a more complex algorithm. But it wouldn't compress it that much so your reset was likely just missed
Here’s the procedure, as others have described. It says a message pops up, but I don’t think I’ve seen that.
https://www.dropbox.com/s/qzr2044rwn...Reset.pdf?dl=0
