Should I get an oil change for my car?
Old Apr 19, 2017 | 04:36 PM
Ubad2's Avatar
Banned
Default Should I get an oil change for my car?
Hi guys.
i got my 2017 F Type R coupe back in August 2016. The car has about 1200 miles on the clock. It's been in winter storage since November 2016. I plan to take the car out from its hibernation by the end of this month. So my question is, should i get the oil changed based on what I've described to you about the car.
Thanks for your input.
Old Apr 19, 2017 | 05:53 PM
Mikey's Avatar
No. Not due yet.
Old Apr 19, 2017 | 06:03 PM
SinF's Avatar
You should, as your oil is likely older than a year by now despite very low miles. Especially if you intend to push the car around.
Old Apr 19, 2017 | 06:06 PM
Mikey's Avatar
I believe synthetics are good for two years, vs. one for dino type oils.
Old Apr 19, 2017 | 06:11 PM
SinF's Avatar
What makes you believe that?
Old Apr 19, 2017 | 06:29 PM
Mikey's Avatar
OEM maintenance schedule on at least one of my cars. Maybe not endorsed yet by Jag.
Old Apr 19, 2017 | 07:50 PM
Unhingd's Avatar
Originally Posted by Ubad2
Hi guys.
As the 2017s were not coming off the production line until April last year, it is unlikely that the oil has been in the car over a year. Finish out the break-in period at 2-3k miles and change the oil at that time.
Old Apr 19, 2017 | 09:24 PM
mwinner's Avatar
I paid out of pocket to have my 1st oil changed at 1100 miles, the car was sitting for 9 mths and had 500 miles when I purchased it. I figured for $130 it was worth the peace of mind.
Old Apr 20, 2017 | 05:41 AM
jaguny's Avatar
If your car was purchased by dealer and warranty started prior to your purchase then in order to get in warranty service you have to change oil after a year of the in service date. I think you have 1 month or 1000 mile variable from that date. As you purchased your 17 in 16 not likely your case, but in any case oil change required if the one year or mileage limit is reached. Just went through this discussion on mine. In any case, if car was new Unhinged's advice is sound. Depending on how much you drive you may be close to the 1 year mark after break in. Check your in service date.
Old Apr 20, 2017 | 05:48 AM
JackMac's Avatar
Unfortunately, Jaguar measures the "one year" oil change from date of purchase, not from date of manufacture (when the oil was actually added to the engine). Something to be aware of when purchasing one of the lot.
Old Apr 20, 2017 | 09:29 AM
Mikey's Avatar
Originally Posted by JackMac
Unfortunately,
Don't you mean 'fortunately'?
Old Apr 20, 2017 | 09:51 AM
JackMac's Avatar
Unfortunately - it delays the date that Jaguar will provide the first "free" oil change under the maintenance plan. 1 year from date of purchase instead of 1 year of the actual age of the oil.
Old Apr 20, 2017 | 10:31 AM
Dogbreath!'s Avatar
The Internet is awash with oil change "experts" that seem to know better than the manufacturer's design engineers. I trust the engineers as do JLR's bean counters who allow the long oil change interval.
Which means that if you follow JLR's recommendation you will be fine warranty wise and not cause any harm to the engine.
But no matter what any of us Internet schmucks say, do what you think is best.
Old Apr 20, 2017 | 11:53 AM
Mikey's Avatar
The oil sitting in a brand new engine is essentially also brand new and uncontaminated. There's no one year calendar limit on oil in this condition any different than oil sitting on the shelf.
