SOS system limited functionality.
Old May 22, 2023 | 03:23 PM
Alan.b's Avatar
Default SOS system limited functionality.
Hi everyone,
as a new member after the purchase of an f type 2018 two weeks ago, haven’t done a lot of miles and the warning sos has come on. It does go out for a short period of time when you press the ok button.
can anyone advise if this is a must to get fixed and is it an mot failure ?
many thanks
Alan
Old May 22, 2023 | 03:38 PM
lizzardo's Avatar
I've no idea about MOT, but when I had that come up it was a battery for the SOS system that needed replacing due to age. For my year it is a two-cell pack, one rechargeable. See this thread for much more information. When I needed mine they were in extremely short supply. hopefully, that has improved.
https://www.jaguarforums.com/forum/f...nality-191247/
Old May 23, 2023 | 03:07 AM
scm's Avatar
scm
Alan
I get that warning (SOS unavailable) if the car has been sitting unusd for an extended period, but it goes away when the car is driven and doesn't come back until some random time later when the car has again been unused for several days.
Not sure about the MOT, but I wouldn't have thought it would be a fail - it's not a safety issue.
These cars are very sensitive to low battery voltage so if you haven't already, it'd be a good idea to get a battery maintainer (lots on here have CTEK MXS 5.0) and make sure you're fully charged - lots of weird errors can arise otherwise.
Old May 23, 2023 | 01:26 PM
Alan.b's Avatar
Guys,
many thanks for all your information and advice, car was out for a run yesterday and again today, no sos warning so far.
thanks
Alsn
Old May 24, 2023 | 04:45 PM
Alan.b's Avatar
Thought all was resolved, out today and the sos warning back and now the engine check light staying on.
car is booked in for a check over tomorrow and will update if any fault codes are confirmed.
fingers crossed not an expensive one.
regards
Alan
Old May 24, 2023 | 05:10 PM
scm's Avatar
scm
Surely if you've just bought the car any faults should be fixed by the supplier - Sale of Goods Act, or whatever it's called these days.
Old May 25, 2023 | 11:37 AM
boomer7's Avatar
I had the same, intermittent warning last fall. Both the information I found on here and the information from the dealer pointed to the secondary battery being low. They replaced it under warranty (I also have a 2018). Btw, the dealer also asked if the auto-stop/start was working (and that had stopping kicking in as well), which, in his opinion, further indicated that battery needed a change.
Old May 25, 2023 | 11:59 AM
scm's Avatar
scm
By "secondary battery" are you referring to the second (smaller) battery in the trunk/boot that was discontinued long before the 2018 models came out? I think the battery that handles the SOS system is embedded in one of the modules in the car (see post #2 above) and has nothing, AFAIK, to do with the stop/start syatem.
Old May 25, 2023 | 04:02 PM
Alan.b's Avatar
Looks as if the problem was a low battery when the car was sitting on the forecourt for sale, when checked today on a diagnostic programme there was 53 related issues, all reset without issue, lights out and running great.
It did say the sos warning system is needing updated and would require a new module, as I understand is expensive.
all good for now.
many thanks for all comments to assist me.
cheers
Alan
Old May 25, 2023 | 04:29 PM
scm's Avatar
scm
I guess that's because the dealers won't replace just the batteries, especially if the customer is paying! I wonder if a decent independent would do the battery swap.
Old May 25, 2023 | 07:51 PM
DJS's Avatar
DJS
…or it’s 3G?
hcardle
XF (X260)
22
Sep 5, 2023 04:23 AM
bigbaddog
Nov 30, 2021 01:39 AM
chiefleaf
XF (X260)
Oct 2, 2021 10:10 PM
MI-FType
Sep 15, 2016 05:13 PM
