Sports Seats Wiring Diagram
Old Aug 28, 2019 | 09:37 AM
urbanpixels's Avatar
Lightbulb Sports Seats Wiring Diagram
Hi Guys,
First post on here and i'm hoping one of your fine people can help me.
I've purchased some seats from a F-type jag. Im not sure of the year. They are manual slide front/rear however the tilt on them appears to be electrical.
Because i wont be fitting these seats into a F-type (they are going in a 1994 supra) i will not have access to the tilt controls. I would like to achieve this with some jerryriging the tilt motor somehow.
Does anybody have a wiring diagram for the seats at all? or know where i can find them?
I've attached a picture of the type of seats they are.
I appreciate any help you can give.
Old Aug 28, 2019 | 09:48 AM
StormtrooperFtype's Avatar
Sadly I can't help with the Diagram but I'd love to see the finished product and hope you will post some photos of your MKIV when its completed with these seats, they look awesome!
Old Aug 28, 2019 | 10:15 AM
DJS's Avatar
DJS
Take a look at pp. 28354-5 of this huge PDF...
https://www.dropbox.com/s/t2hfjv7bas...anual.pdf?dl=0
It doesn't show the wiring inside the seats, but it does show the harness that connect to the seats, and therefore the pinout of the connector on the seat. The top of that section on wiring explains how to read the drawings.
Old Aug 28, 2019 | 10:44 AM
lizzardo's Avatar
Those are the Performance seats, not Sport, in suedecloth. Other than that, I'm no help at all. A question though: do you know what they weigh?
Old Aug 28, 2019 | 12:00 PM
A lot
I can weigh them at weekend if you want to know
Old Aug 28, 2019 | 12:10 PM
Wow that looks awesome and what i'm looking for. How to interpret it is another matter. Im wondering if i could just apply 12+ to the squab incline/recline...
Old Aug 28, 2019 | 01:32 PM
xrix4096's Avatar
I would expect that to work
Old Aug 28, 2019 | 04:12 PM
Cheers ive had a good search last few hours and I can’t see why not.
ive planned to use some electric window switches which can take a single 12v feed and swap the polarity between motor outputs for each direction I could also use a double switch for the recline and seat base raising.
Old Aug 28, 2019 | 04:14 PM
This is what the seats will be fitted in also for anybody interested.
im excited to see how it fits and works
Old Aug 28, 2019 | 04:46 PM
xrix4096's Avatar
I guess it would depend on the switches you use but I’d run via a relay rather than trying to get all that current through the switch itself as I doubt most modern ones are designed for it. Unless of course the seat already has relays. Did the seat connector have general +12/gnd inputs as well as inputs for the various functions?
Old Aug 28, 2019 | 05:17 PM
Cambo's Avatar
Try to find some labels with part numbers on the seats somewhere, because the seat wiring totally changed for the 2018MY.
Part numbers starting with EX53 (2014), or JX53 (2018).
Old Aug 28, 2019 | 06:54 PM
Unhingd's Avatar
Those are indeed the performance seats , but I don’t believe they ever came with a mechanical slide. They were always 14 way electrically adjusted.
Old Aug 29, 2019 | 01:44 AM
the seat has a ecu in the bottom of it where everything connects and will be can controlled id imagine. I’m not too clued up on electrics but I can’t see how a relay would help it’s just another switch most window switches are rated for 12v 30a which I expect is enough
there is a part number sticker I will check this can get back to you
they are definitely mechanical slide it’s the only reason I bought them as I wouldn’t have the electrical control you can see the arms here:
Old Aug 29, 2019 | 09:24 AM
xrix4096's Avatar
[QUOTE=urbanpixels;2119416]the seat has a ecu in the bottom of it where everything connects and will be can controlled id imagine. I’m not too clued up on electrics but I can’t see how a relay would help it’s just another switch most window switches are rated for 12v 30a which I expect is enough
If the switches are rated that high then I'm sure you're right. Also if the seat has it's own ECU then even if the motor lines are just signals that'd still be OK
Old Sep 17, 2019 | 05:43 AM
Hi Guys,
I managed to finally fit these to my supra. All the electrics is working too. Thanks for the excellent information here.
Some pics:
3d Printed a little holder for the recline switches.
Old Sep 17, 2019 | 05:48 AM
scm's Avatar
scm
It's a start. When will you upgrade the rest of the car?
Old Sep 17, 2019 | 07:24 AM
fujicoupe's Avatar
Banned
Ouch!
Old Sep 17, 2019 | 08:54 AM
DJS's Avatar
DJS
Hi Guys,
Some pics:
That's great. Glad we could help, and thanks for stopping by.
Old Sep 17, 2019 | 01:27 PM
RGPV6S's Avatar
That was a bit harsh.
Old Sep 17, 2019 | 01:30 PM
scm's Avatar
scm
British humour, just a joke (spot the smiley).
