Srs light stuck on
Old May 20, 2026 | 03:24 PM
shanelaughlin's Avatar
Default Srs light stuck on
Hello everyone, I have swapped the interior on my 2014 jaguar f type from oyster to red interior from a 2017 jaguar f type. I now have a srs code that when I clear will not go away. When I use my code scanner it clearly shows the vin from the old car which ends in 0258 and the last 4 of my vin is 4858. I did swap the modules over from the original seats to the new seats to get them out of inch mode. Is there anyway that I can reset this light or reprogram the seats to have the same vin as my car now to get rid of the light?
Old May 20, 2026 | 08:35 PM
RoverJoe's Avatar
Community Influencer
No, you cannot overwrite the VIN. Can you swap the modules over from your old seats?
Old May 20, 2026 | 10:16 PM
I have already swapped the modules for the seat over to the new seats and all I got was them to more normally but still have a srs light
Old May 21, 2026 | 08:07 PM
RoverJoe's Avatar
The invalid VIN codes should clear if the modules have been put back to normal. Might require a hard battery reset to clear it out if not using an OEM level tool. RCM is pretty tough.
ameritoo
E type ( XK-E )
Dec 24, 2020 03:24 PM
ericjansen
Jun 1, 2019 08:27 PM
Segfault
May 16, 2018 02:00 PM
XJR 308
Dec 14, 2016 04:02 PM
vin likes diesel
Jul 27, 2013 02:44 PM
