Starting Issue
Old Jan 31, 2025 | 04:07 AM
blitzsah's Avatar
Default Starting Issue
Hello guys,
I am looking for some help with a starting issue I'm having. I have posted the same on ftype forum but there seems to be more activity here so maybe someone will be able to help.
Car is F Type SVR 2018 (UK).
Initially, the car would not crank and there was only a click on starting. Got underneath the car and gave the starter a tap whilst my partner pressed the start button and it fired into life.
So booked in for a starter replacement. New starter fitted to car, now the mechanic is saying the engine cranks fine but it doesn’t actually fire up.
This is odd because the engine was working fine previously, I drove it to the workshop.
He has tested for a spark and apparently there’s no spark. But there’s also no codes stored.
He has sent me a video and it seems like when the cranking is manually stopped with the button, the car splutters a bit as if it’s only getting ignition when the starter motor stops getting power.
We have tried boosting the battery and jumping but still the same issue.
Any ideas/thoughts are welcome. Thank you!
Old Jan 31, 2025 | 06:20 AM
Adam Deermann's Avatar
Perhaps a starter relays?
Old Jan 31, 2025 | 06:29 AM
JagCode3's Avatar
Fuel pump connector dislodged?
Old Jan 31, 2025 | 08:48 AM
blitzsah's Avatar
Will be checking the Ignition relay tomorrow so will report back. Seems odd that this would fail though.
Old Feb 1, 2025 | 09:08 AM
SportsEngineer's Avatar
Is it similar to this? My 2015 R RWD would fail to start as well. Turned out to be a loose ground strap on the chassis. Video in the link below:
https://www.jaguarforums.com/forum/f...9/#post2755874
Old Feb 1, 2025 | 10:47 AM
blitzsah's Avatar
No. The engine cranks but there is no spark now.
Initially, the problem was similar, but we confirmed that the starter motor was faulty. After replacement, now the engine won’t start but will crank.
Old Feb 4, 2025 | 02:49 PM
DJS's Avatar
DJS
Here’s a document on the starting system…
https://www.dropbox.com/scl/fi/fturj...=ns81kk9u&dl=0
Old Feb 5, 2025 | 03:58 AM
bfrank1972's Avatar
As sports engineer mentioned, confirm your primary grounds on the car are all clean and secure. There are several on the car. May not be the issue but it is very easy to check. Can cause all sorts of issues - these are complex, computer driven cars, they're not your old Chevy BTW these do not have the traditional "starter relay" either. Also how old is your battery? If it is more than 5-6 years old, replace it.
Old Feb 15, 2025 | 10:14 AM
blitzsah's Avatar
Update on this one. The starter that was used originally was bought via eBay, it was a denso starter with part number T2H3246
I found this from https://parts.jaguarlandroverclassic.../brand/jaguar/
The starter motor that came off the car had part number: GX73-11001-EC
The denso and the one that came off the car looked completely identical. Same number of teeth and kw rating etc.
I decided to source a second hand starter with the exact part number that came off the car.
After this one was fitted, car started no problem. So I’m not sure why, but the denso did not work, and it was a brand new part.
Old Feb 15, 2025 | 12:20 PM
JagCode3's Avatar
Great detective work! Glad you are back up and running, thanks for letting us know the solution.
gooseman1107
Nov 12, 2023 07:28 PM
oxendine
Jun 1, 2022 08:50 AM
MattsJag91
XJ40 ( XJ81 )
Jun 5, 2021 02:46 PM
semorex
Jun 12, 2020 08:47 AM
vlaicu
Sep 3, 2019 01:10 PM
