Steering wheel control button not working
Old Apr 10, 2024 | 11:18 AM
robsjag14's Avatar
Default Steering wheel control button not working
My first post on the site. 2014 F Type S is new to me. Can't get the menu buttons on the left side of the steering wheel to work so i can't access the menus. Do I need a new switch? Should I try contact cleaner with it in place or do I need to remove the steering wheel and pop out the control box to try it? Thanks
Old Apr 10, 2024 | 01:57 PM
Carbuff2's Avatar
Hi and WELCOME.
Has your F been retrofitted with CarPlay/Android Auto? Some of those conversions will not operate the buttons.
If your F is stock, it could be the buttons or even the 'clockspring' electrical connection in the steering wheel.
How many miles?
Old Apr 10, 2024 | 02:10 PM
robsjag14's Avatar
The car is stock as far as I know. How would I know if the CarPlay/Android Auto is installed? It paired up with my Samsung phone (android) very easily when I first got it in February. It has 26,000 miles on it.
Old Apr 10, 2024 | 02:41 PM
Carbuff2's Avatar
Most of the CarPlay adapters use the AUX setting. Try it & report back.
Oh Yeah, they also render the NAV system inop since the SAT/NAV antenna is hooked up to the adapter.
Search found:
https://www.jaguarforums.com/forum/f...issues-254903/
and
https://www.jaguarforums.com/forum/f...ht=UAD+CarPlay
At 26K miles it is unlikely to have a broken clockspring, tho' replacing the 'sticky button' issue sometimes requires removal of the steering wheel controls....
Old Apr 10, 2024 | 08:37 PM
DJS's Avatar
DJS
I think the CarPlay/AA adapters don’t kill the menu button? I’d suspect the buttons or the clockspring.
Old Apr 15, 2024 | 05:09 AM
Pauluucho's Avatar
Default Operates in ignition only position
The full menu is not accessible while driving - only the audio functions. in the 'ignition only' position you should be able to access the full menu.
Old Apr 15, 2024 | 05:52 AM
DJS's Avatar
DJS
?? My menu options aren’t limited while driving, or not limited much.
R8WAY
Apr 11, 2024 06:46 AM
djw2133
Jun 7, 2023 01:01 PM
user 652867429824
Nov 28, 2022 01:16 PM
Barclay1974
Oct 12, 2021 06:24 AM
May 26, 2007 03:41 AM
