Buttons on Steering Wheel not Functioning
Old Oct 7, 2021 | 10:10 PM
Barclay1974's Avatar
Default Buttons on Steering Wheel not Functioning
Hi All,
Recently all of the buttons on the steering wheel have stopped working on our 2006 XJR. Volume buttons, cruise control, horn are all not working. I have checked several fuses but none were bad that I have found so far. Turn signal, lights, wiper controls all work, it's just the buttons. Just wondering if anyone has had this issue before and if you did what was the cause.
Thanks in advance for any help or ideas.
Old Oct 10, 2021 | 04:52 PM
meirion1's Avatar
Probably a clock spring fault-maybe just needs a clean.
Remove plastic 'box' behind steering wheel to access.
https://www.google.com/search?q=jagu...hrome&ie=UTF-8
Old Oct 10, 2021 | 06:54 PM
Wingrider's Avatar
Sure hope your lucky, & a cleaning works.
Old Oct 10, 2021 | 07:11 PM
Bob Hornby's Avatar
If the problem is the ribbon then you just need to replace the "indicator cancelling cassette" which has the ribbon in it. I did this a couple of weeks ago. it cost me $100 (Australian) and came from the UK.
Bob
Old Oct 12, 2021 | 06:24 AM
Thank you for the replies. This has given me the information I needed to get better search results on how to do this. I will post my results once I get a chance to get it apart to look at it closer.
frankmarroquin
Jan 28, 2025 10:04 AM
hwverwoerd
Jan 23, 2020 02:01 PM
poisonpill
Mar 16, 2018 06:47 AM
max224
Jul 10, 2014 08:06 PM
rsigue
Jun 7, 2011 09:52 AM
