Stuck headlight bulb
Old Oct 24, 2022 | 08:14 PM
rts1021's Avatar
Default Stuck headlight bulb
Trying to replace my headlight bulb. Got the bottom clip undone and was able to rotate the two tabs clockwise but there are metal tabs on both sides of the bulb that seem to be gripping it and preventing it from coming out. (They can be seen on the left of the bulb in the pic) Is there a trick to releasing these?
Old Oct 24, 2022 | 08:49 PM
OzXFR's Avatar
If you are talking about the wiring plug on the bulb then yes it can be a little tough to remove, I found that the easiest way was to use a small flat blade screwdriver to lever those metal tabs up/off.
Old Oct 25, 2022 | 12:26 AM
Holy F type's Avatar
they are tight on, try to wiggle them out. maybe pry them back a little bit
Old Oct 25, 2022 | 01:44 PM
mcphill's Avatar
They just act as a big clip. Pull harder.
https://www.jaguarforums.com/forum/f...-bulbs-262226/
Old Jan 4, 2024 | 08:24 AM
thistle4celtic1's Avatar
Last edited by thistle4celtic1; Jan 4, 2024 at 08:29 AM. Reason: Wrong thread…opps
karamayoko
Oct 23, 2022 08:48 AM
Higgins
Jul 19, 2019 02:04 AM
Robert Grisar
May 19, 2018 07:10 AM
belladad
Feb 27, 2011 02:02 PM
enginefxr
Mar 29, 2009 10:10 PM
