Supercharger coupler change and increased rattle
Old Apr 28, 2025 | 08:16 AM
ufok's Avatar
Default Supercharger coupler change and increased rattle
Good Day Ladies and Gents,
recently, I replaced the faulty OEM spring coupler for my 3.0 V6S F-Type supercharger.
I replaced it with a solid coupler from Powerhouse automotive UK.
After replacement, the supercharger works fine, but the characteristic rattle has increased a lot.
attached, a short video.
is this normal? When the engine is in cold condition and I am driving with an open top, the rattle can be heard quite noticeably.
kind regards,
Ufok
File Type: mov
Old Apr 28, 2025 | 08:44 AM
Doug5.0's Avatar
Great question, as I am in the middle of the exact same situation. I took the supercharger off to change out the coolant pipes, and several months after putting it back together this noise got worse and worse. So I thought it was the coupler.I bought the car used, and took the supercharger apart to replace the coupler and found the coupler was already replaced! I’ve heard the noise is both normal, and others say it’s not. It’s expensive, but I’m actually sending my supercharger off to Eaton to be rebuilt. New bearings and new shaft. I’m at 60,000 miles so I wanna make sure all is well. We’ll see what others say. Thanks. Good luck.
Old Apr 28, 2025 | 09:17 AM
Evoex's Avatar
From what I recall aftermarket couplers are notorious for noise.
I just had mine replaced (OEM) and zero issue
Old Apr 28, 2025 | 12:13 PM
sov211's Avatar
The same here.
Old Apr 28, 2025 | 03:25 PM
dennis black's Avatar
Here's the problem some times the bearings in the snout go bad, after the rattling of the bad coupler damage happens not all the time but the ones ive worked on the bearings get bad also ,so I would change the snout when doing the coupler for piece of mind ,the snout can had for $126 us Dollars, when I replace a coupler for a members jaguar I change the snout and the coupler, also there's some fake solid coupler out there ,in my video it explains it
Old Apr 28, 2025 | 07:48 PM
OzXFR's Avatar
Yep, the warranty fix for a rattling coupler was replacement of the entire snout, ask me how I know!
Funny thing is after I had the snout replaced it still rattled (and still does) but at least the "clonk" on shut down went away.
I have never been 100% convinced that the JLR dealership really did replace the snout, no witness marks on any bolts that I can see.
Old Apr 28, 2025 | 09:43 PM
samit's Avatar
Do you mean the Jaguar spring coupler? Because several folks have reported increased rattles with Eaton solid couplers too:
https://www.jaguarforums.com/forum/f...5/#post2788789
Old Apr 28, 2025 | 10:07 PM
The couplers that i install in members cars are solid by ZZP OR any that are not fake they must fit tight and i mean tight ,the fake ones will slide on easy and melt , took one of a 2016 F-TYPE and this is what it looks like ! after 3 months ,then i installed a original ZZP . You can go back to stock but then you have to pull the snout again ,the one i use is ZZP, ITS lasted a couple years now and the ones I've installed in members cars are quiet and reliable
Fake one
Old Apr 29, 2025 | 09:24 AM
clubairth1's Avatar
Community Influencer
If you suspect SC noise it's very simple to remove the SC belt and drive the car. It will set no lights but it will be a DOG to drive and you will have a much larger appreciation of how much power the TVS blower's add to the engine.
If your interested we have many threads on solid and spring couplers and things have went back and forth over the years. I also have the shut down "clonk" and have for many miles. Be aware the factory Eaton solid couplers come in several sizes and it's not real clear what part number to use. I have the supposedly correct solid Eaton coupler but ran across a great deal on a complete OEM snout that I picked up too. I will decide which way to go when this is swapped out.
Iticip
Oct 30, 2025 04:28 PM
Rodkel
Oct 14, 2023 10:23 AM
WaterDragon
Jul 2, 2021 06:01 PM
Supercharged81
Aug 19, 2019 06:10 AM
ukdude
Mar 7, 2015 07:38 AM
