Suspension related question
Old May 19, 2020 | 09:02 AM
pauledddy's Avatar
Default Suspension related question
Afternoon all,
Has anyone been able to disable the CATS suspension when upgrading to coilovers? Or other aftermarket suspension set up?
Old May 19, 2020 | 06:13 PM
OzXFR's Avatar
Are you sure you are in the right sub-forum?
No F-Type ever came with CATS and you have to go back to the pre-2009 Jags before you find one with CATS.
Old May 20, 2020 | 02:26 AM
pauledddy's Avatar
I'm sure the F Type has the same suspension as the 2010+ XKR. Which is different the the pre 2009 XKR's?
Old May 20, 2020 | 07:04 AM
DJS's Avatar
DJS
Here’s a document on the F-type suspension, including how the active shock absorbers and dampers work...
https://www.dropbox.com/s/p8jkgw63ql...nsion.pdf?dl=0
Old May 20, 2020 | 07:16 AM
JacksonvilleJag's Avatar
Originally Posted by pauledddy
... when upgrading to coilovers?
I thought the F Type already has coilovers.
Old May 20, 2020 | 09:18 AM
Unhingd's Avatar
The term coilover refers to springs That are integrated into the shock absorber In such a manner as to allow the spring preload and/or ride height to be adjusted. No such adjustment in the OEM coils that happen to fit over the OEM shocks.
Old May 20, 2020 | 10:41 AM
Thumbs up
Ahhh, got it. Thanks!
bad94flstn
Oct 5, 2012 11:04 PM
TomServo
May 16, 2011 01:21 PM
gonmaro
XJ40 ( XJ81 )
Apr 22, 2009 12:02 PM
