SVR fender on R
Old Apr 15, 2017 | 06:47 PM
Jabooh1's Avatar
Default SVR fender on R
Has anyone put the SVR fender (or the like) with the vent on an R?
Old Apr 15, 2017 | 07:43 PM
Stohlen's Avatar
Someone here did, and they fit. I couldnt find the post, I think it was in some random, unrelated thread. But there are pictures of it.
Old Apr 15, 2017 | 07:49 PM
Jabooh1's Avatar
Thanks! I searched but couldn't get the right combination of words I guess.
I really like the vertical vent look.
Old Apr 15, 2017 | 08:19 PM
zmoothg's Avatar
It was I who did it. In order to complete the conversion, you will need the SVR side skirts which are different from the R and the fenders which are two pieces each side. The only piece I cannot find is the hood vents for the SVR.
Old Apr 15, 2017 | 08:26 PM
zmoothg's Avatar
Old Apr 15, 2017 | 08:35 PM
Jabooh1's Avatar
Looks good. I wonder if it will work on a 2015 which has different side skirts as well. Or was yours an older model and now if just looks like a 2016+?
Old Apr 15, 2017 | 09:44 PM
zmoothg's Avatar
It should work fine. They haven't changed much in between models and years. The svr side skirts will definitely fit. I can go check on topix for you to see if any of the fender bolt points have changed but I highly doubt it.
Old Apr 15, 2017 | 10:00 PM
Stohlen's Avatar
They have not; mine was built with one of each.
Old Apr 16, 2017 | 09:07 AM
Nati's Avatar
No worries there. If I had an svr I'd be looking to swap out the fish gill hood vents. I think they're the worst design element of the model.
Old Apr 16, 2017 | 09:28 AM
amr42's Avatar
Does this mod turn the <normally blank> front vents into functioning front brake cooling devices?
If so, did you notice any difference with less brake temp overheating? Guess it depends on what brake package you have fitted to your R...
Old Apr 16, 2017 | 12:09 PM
zmoothg's Avatar
I haven't swapped out the front bumper to the SVR version as you can see in the photo. I've been on the fence about this change. I quite like the non-SVR bumper, the lines match the car better, but the SVR bumper does have an more aggressive edge. So no, right now they are still blanks in my grill.
Old Apr 16, 2017 | 12:41 PM
Ubad2's Avatar
Banned
Default Question about getting a SVR front bumper
Does anyone know the best place to buy the SVR front bumper? I've been considering getting it but still undecided. Thank you.
Old Apr 16, 2017 | 04:28 PM
zmoothg's Avatar
https://www.jaguarpartsunlimited.com/. You will need to have a valid SVR vin
Old Apr 16, 2017 | 04:55 PM
Ubad2's Avatar
Banned
Default zmoothg, question for you
I suspect getting a SVR VIN # is easy enough. Is this place, the best with pricing ?
Thanks!
Old Apr 16, 2017 | 05:11 PM
zmoothg's Avatar
Thanks!
It's the best I've seen accessible to mere humans like myself. Shipping for the bumper though might remove all the discount offered by them. I ended up not purchasing the SVR rockers through them because the shipping cost essentially negated the savings. make it it not worth it to purchase from them. I ended up just going through my local dealer parts department, for the rockers, and the dealer was nice enough to sell me parts at wholesale cost. Shipping is free via the dealer.
Old Apr 16, 2017 | 08:24 PM
Unhingd's Avatar
Just look up an SVR on Cars.com and pull a VIN off their website.
Old May 28, 2017 | 05:35 PM
Cj10jeeper's Avatar
Might be of interest but I've just fitted an SVR front bumper onto an S.
Not the hardest mod, but a few catches. Needs SVR undertray, loom modded to extend for outer parking sensors and some fettling of the aux rad cowl.
Happy to post more info if folks want it, but all bits needed can be picked up from a main dealers, although I sourced the bumper online.
Added to the colour coded '400' series sill extensions I think it makes a worthwhile set of external cosmetic mods.
Attached Thumbnails SVR fender on R-img_3475.jpg   SVR fender on R-img_3478.jpg   SVR fender on R-img_3477.jpg   SVR fender on R-img_3479.jpg   SVR fender on R-img_3481.jpg
Old May 28, 2017 | 07:06 PM
Ubad2's Avatar
Banned
Default Very nice, looks great !
I have a question for you, are the left and right side area of the SVR bumper functional allowing free air flow through the mesh screen or is it only cosmetic for the two corner inlets of bumper.
thank you
Old May 29, 2017 | 03:11 AM
Cj10jeeper's Avatar
They are functional. The grille has a blanking plate behind it that covers around 3/4 of the area leaving a vertical vented strip at the outside edge.
However as i still have the standard wheel arch liner there is nowhere for it to vent to the brakes.
I'm sure the SVR would have trumpets to direct airflow across the void and out the liner towards the brakes.
Old May 29, 2017 | 10:54 AM
XFactoR's Avatar
Hmmm .... interesting ....I always drive conservatively the first 500 miles and then gradually get on it....just what I do.
