Recently picked up a 17 F-Type SVR, I simply love it! The sound, the drama, the speed. Certainly the fastest car I have owned to date. I picked up the Dragy and took it out to the drag strip to get a baseline before I start to go down the path of mods, drag strip sits at 2300ft elevation. I did 5 runs, dynamic mode, S gear, used launch control, some runs with and without traction control. Very consistent times, attached a video. However I have seen better times stock. Is it just my elevation that is limiting or something else I am missing?
The NHRA uses a correction factor to compensate for altitude for stock/super stock classes. To accurately convert your ET, find your altitude with the chart below and convert your quarter mile ET and MPH to sea level times.
Here's how you do it: Simply multiply the elapsed time factor below times your ET or MPH.
ET Example: 16.1 x .9692 = 15.60412 corrected ET
MPH Example: 84 x 1.0325 = 86.73 corrected MPH
To find the elevation of the track where you drag race, check out the Geographical Nameserver. Enter the city, state and the server will find the info for you.
Your 2300' elevation run of 11.83@119.31 would convert to 11.51@122.68 at sea level. That seems pretty reasonable for a stock SVR. Nice job!
*An Important Update* - In my haste to try to be helpful, I grabbed correction factors for a normally aspirated engine. With our F-Types being supercharged, elevation (or density altitude, more accurately), has much less impact. Here is a good website where you can calculate corrected 1/4 mile times and speeds for different conditions and different types of engines - https://www.dragtimes.com/da-density...calculator.php. Scroll to the bottom to enter your original data and see corrected results. Use the last option (Extensively Modified Supercharged and Turbocharged Engines) for an F-Type. Also, if you have an Android phone, you can use the app Drag Racing Weather Station (https://play.google.com/store/search...=apps&hl=en_US) to pull in live weather data for most drag strips and use the Density Altitude for your corrections.
From my personal experience, ambient temperature has a significant impact on performance for our F-Types due to hotter IATs. At higher elevations, the supercharger has to work harder to hit target boost, which will likely further increase IATs. I have not found a good method to correct 1/4 mile times for this effect.
Reason: Updated for more accurate information.
That is super helpful, thanks for this! Help with my thoughts of it not performing to spec. I feel then once it is off the all seasons it came with and it is on some semi-slicks should grab another tenth.
I have updated my original reply to include the following:
What were your 60-foot times from the drag strip? That is your best indication of traction limitations and launch technique.
For comparison, here are the time slips from a couple of my passes earlier this year. Note that I am VAP Stage 3. There was a pretty decent headwind the night I ran these times, so trap speed was lower than expected.
Those times look very respectable for a stock SVR. Also, I'm jealous of the digital time slip with the Density Altitude included at the bottom. I run at Indianapolis Raceway Park, home of the US Nationals, and we just get old-school paper time slips.
I dug up my stock time slips and here is one for comparison. IRP runs around 1000' DA most of the time.
