switched power wire under the hood
Old Aug 25, 2020 | 08:23 AM
nitro28's Avatar
Default switched power wire under the hood
I am adding a wireless camera for the front lip of my car. The wireless unit needs power under the hood. I don't want to connect it to constant power because it will slowly drain my battery when I am not using the vehicle. Any suggestions on a wire to tap into that only comes on with the ignition? I don't want to have to come back through the firewall if possible. This is on my 2017 F Type R Convertible. Thanks
Old Aug 25, 2020 | 10:34 PM
takeapieandrun's Avatar
Kind of a bandaid fix, but on my old car I used a product that was basically an engine vibration sensor, when the car was on it would connect the circuit from the battery to whatever peripheral you spliced in. I can't find it on Amazon now though, but maybe you'll have more luck.
Old Aug 26, 2020 | 05:02 AM
JgaXkr's Avatar
I have done the exact same thing. You can get ignition power from the fuse box next to the brake master cylinder.
Old Aug 27, 2020 | 02:38 PM
nitro28's Avatar
Cool thanks. DId you just use one of the little blue splicers to tap into that wire? Was it pretty easy to get to in that fuse box? Thanks.
Old Sep 7, 2020 | 09:07 AM
nitro28's Avatar
Can someone elaborate on which wire exactly I am tapping into? Thanks.
lair12
I-Pace EV
Apr 5, 2020 05:00 PM
iramphal
Jan 7, 2019 11:19 AM
lckitty
Mar 26, 2017 08:39 PM
hoodun
Dec 11, 2014 07:05 PM
spuds1956
Sep 24, 2010 04:15 PM
