Is there an upper footwell trim on the F-Type?
Old Aug 29, 2016 | 07:27 AM
xdave's Avatar
Default Is there an upper footwell trim on the F-Type?
I noticed that above the footwells on my coupe there are moulded locating lugs and holes for fir tree clips that look like they were designed to retain a moulded trim panel (on the current jags they are made from pressure-pressed cloth). I mean the trim cover where the footwell lamp would normally clip, that would have a cut out for vents and the ODBII port, etc., often called a lower fascia cover. However mine has no trim panels on either side. I can't find any in the parts catalogue, so is this something they designed in but later decided not to include on the F-Type, or am I missing some trims?
Old Aug 29, 2016 | 03:51 PM
Unhingd's Avatar
No trim panels on mine either.
Passenger side:
Seems like there should be a trim panel there.
Old Aug 29, 2016 | 04:04 PM
xdave's Avatar
If you sit in either seat and lift your foot up, do your toes hit a trim piece closing off under the dash or can you touch the wiring and modules with your feet?
I have circled in green the moulded supports with holes that were clearly designed to support fir tree clips holding a trim piece to close the void. There are also moulded supports behind the pedals. The workshop manual shows the trim missing as it is in my car so I suspect it was designed out before launch but just wanted to check it's not just mine.
Attached Thumbnails Is there an upper footwell trim on the F-Type?-en_us.jpg
Old Aug 29, 2016 | 04:05 PM
xdave's Avatar
Thanks for checking Unhingd, I'm glad it's not just mine.
Old Aug 30, 2016 | 12:35 AM
Mpowerr's Avatar
I don't have them either. You beat me to it, I was gonna ask the same question...
BobRoy
49
Sep 18, 2016 10:48 AM
markbridge
Apr 8, 2016 10:53 PM
Dec 12, 2006 10:03 PM
Feb 23, 2006 01:21 PM
