Tire Leak
Old Feb 13, 2023 | 11:00 AM
donovanwestover's Avatar
Default Tire Leak
Anybody ever had an unexplainable issue with an irreparable F Type tire leak? I have the Pirelli P Zeros as well as the factory wheels. My experienced autohouse cannot seem to figure out how to keep pressure in the tire.
Old Feb 13, 2023 | 11:31 AM
lizzardo's Avatar
It's coming out somewhere. How fast is it losing pressure? I can't believe that an experienced shop can't figure it out. Remove the wheel and get a spray bottle of soapy water. Check the beads on both sides, the valve (both where it goes in the rim and the valve core, tread, and sidewalls. The only thing left is the rim itself. That's really rare, but not unheard of.
Old Feb 13, 2023 | 05:03 PM
Jay_Davis's Avatar
I've had where the valve has an issue because it has the pressure sensor built in. There's a refurb kit for those pressure sensor valves which is only a few bucks which fixes it and can be easily done by most tire shops.
Old Feb 13, 2023 | 08:35 PM
BritCars's Avatar
Any chance there is a micro crack in the wheel itself? I had that once and it took a while to find it. Quite a slow leak. About 1-2 weeks to loose 5psi.
Old Feb 13, 2023 | 08:52 PM
Thunder Dump's Avatar
Assuming the tire is 100% puncture free, the most common cause of a slow leak would be a loose or bad valve. Second most common would be leaky bead (usually from debris between tire and rim). I've seen a small pebble get in-between and cause a slow leak. Hairline crack in rim is third, but could also be the cause.
Old Feb 14, 2023 | 09:33 AM
00by's Avatar
If it turns out to be a tyre, just see it as a good opportunity to ditch the P-Zero's!
Old Feb 14, 2023 | 03:10 PM
Carbuff2's Avatar
I've had issues with the tire valve>wheel area, loose valve stems, or slow leaks because of the barcode stickers that the manufacturers place in the bead surface of the tire.
But usually its because the tire store monkeys scratched the bead area during removal reinstall.
If your 'autohaus' can't resolve it, go to a Firestone...
Old Feb 19, 2023 | 03:04 PM
GeorgeIII's Avatar
I never have issues with tires.... I just fix them.
BlkCat
Dec 8, 2021 04:13 PM
carzaddict
General Tech Help
Mar 24, 2020 08:35 PM
r0m8470
Aug 28, 2013 10:45 AM
jaguarcraver
Jun 1, 2011 08:26 PM
RayG
Feb 26, 2011 07:42 PM
