trickle charger 2014 Ftype
Old Dec 3, 2018 | 09:51 AM
Mattnmal82's Avatar
Default trickle charger 2014 Ftype
Where do I install the trickle charger on my 2014 Ftype?
Old Dec 3, 2018 | 11:26 AM
sov211's Avatar
I hope you mean a battery maintainer (such as the CTEK) and not a trickle charger. There are two possible installation points. The first is under the hood/bonnet, right side. You will find the positive connection point under the red cover, clearly marked. The negative connection point is the nearby threaded post. But a much better connection place is in the trunk/boot area and there is a thread on this (look for "CTEK charger")...the two connection points are: negative - any bolt on the trunk floor, and positive: any point on the bar under the black plastic cover to the right of the main battery, the yellow wire connection point being the most commonly used for convenience. But any one will do.
While you are in there you can easily disable the start/stop system if it bothers you. Simply disconnect one of the leads on the small battery to the right, and wrap the connector for safety. Done! There is no negative effect, but there is the positive effect of eliminating the annoying stop/start (and the wear and tear on the starter).
Old Dec 3, 2018 | 06:51 PM
uncheel's Avatar
Check out the "How To" sticky thread for this and other helpful hints.
(For pictures, see my post, #39.)
I'll second the suggestion for CTEK, such as:
https://www.amazon.com/gp/product/B006G14FK8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B006G14FK8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Consider getting an extra eyelet that you can leave one attached to the battery:
https://www.amazon.com/gp/product/B002MT8S7E/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B002MT8S7E/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
(I put one on the F-Type and another on my lawn tractor.)
Old Dec 4, 2018 | 09:42 AM
sov211's Avatar
Mattnmal82:
was any of the information above helpful? If so, we'd like to hear from you...if it was not helpful, what more can we tell you?
Old Dec 4, 2018 | 09:52 AM
DJS's Avatar
DJS
Here is how I hooked up my Battery Tender Jr since Dec 2013:
https://www.jaguarforums.com/forum/f...2/#post1299286
Just put it away for its 6th winter, no battery issues.
Dick
Jan 30, 2019 04:14 PM
BlkC4t_XK14
Dec 9, 2018 02:40 PM
Langstraat
Dec 5, 2018 07:58 AM
Steveg214
Dec 2, 2018 07:00 AM
dolmar
Nov 28, 2018 04:29 PM
