Trim part code
Old Apr 23, 2020 | 04:55 AM
ahmad.366's Avatar
Angry Trim part code
Hi guys,
I have been struggling to find the part code for the plastic seat trim for my 15 F type R. here is a picture
cracked plastic trim
Old Apr 23, 2020 | 05:19 AM
It's definitely called Mechanism Cover and looks like the two piece items 2 and 3 rather than the one piece item 2 or item 11 in this JEPC extract. Being able to compare this with your vehicle will give you a better idea than I can get only by looking at the diagrams:
After that it starts to get complicated. VIN and colour are involved in determining the correct part numbers for these.
Old Apr 23, 2020 | 05:31 AM
ahmad.366's Avatar
thanks Graham! Suddenly it looks really complicated. I suspect part 1 and 3
here are clearer pictures:
Old Apr 23, 2020 | 07:09 AM
I think the part numbers are:
Item 1: T2R5465PVJ
Item 3: C2P21706LAA
Check before you order.
Jaguar are showing them as not available to order online. Dealer supplied only. This is likely to cause delay as I expect the JLR international distribution centre in Frankfurt, Germany is presently closed due to the pandemic. Good news is the cost is a lot less than I was expecting. Here in the UK item 1 is 35 UKP and item 2 is 29 UKP.
Old Apr 26, 2020 | 01:09 AM
ahmad.366's Avatar
Thanks, Graham.
I will take the car tomorrow to open the parts and see the ID behind each.
Old Apr 30, 2020 | 09:56 AM
ahmad.366's Avatar
@Graham,
here are the parts. took multiple photos since the parts have multiple numbers
Old Apr 30, 2020 | 06:29 PM
Unhingd's Avatar
Originally Posted by ahmad.366
@Graham,
Unfortunately, none of those numbers look like a Jag part number. The actual part number on these 2 parts depends on the color of the plastic. You should find what you need on this parts explosion:https://www.suburbanautoparts.com/v-...and-components
Old May 1, 2020 | 04:51 AM
ahmad.366's Avatar
Thanks, found something for cheap, if the color is different, I'm just gonna paint them or keep them as is
andersh
Jun 8, 2022 07:59 AM
Gary A
Dec 30, 2019 10:58 PM
Papadog
Apr 23, 2017 03:18 AM
brinny
Mar 30, 2016 06:55 AM
sklimii
Jan 22, 2013 01:23 AM
