trying to find tool to remove rear wing
Old Apr 22, 2022 | 04:57 PM
santacruz11's Avatar
Default trying to find tool to remove rear wing
have a 2016 f type and am at a loss to find the correct tool to remove screws inside rear wing
Old Apr 22, 2022 | 06:26 PM
lizzardo's Avatar
The ones holding the moving panel to the mechanism are torx. The ones holding the mechanism base to the hatch are security pentalobe (5-sided). There's information on it in a couple of places, but the DIY here might be the most help.
https://www.jaguarforums.com/forum/f...thread-242078/
Old Apr 22, 2022 | 06:30 PM
powerhouse's Avatar
You need these , I got on Amazon when changing to fixed wing
Old Apr 22, 2022 | 07:15 PM
OzXFR's Avatar
They are also known as "star security" 5 point TS27 screws (where TS stands for "Torx Security"), that is what I bought/used and it worked perfectly.
You want the five sided one with the hole in the middle, size 27.
Old Apr 22, 2022 | 08:42 PM
thanks to all bought two sets none of which fit, will press on thanks again
Old Apr 22, 2022 | 08:54 PM
kb58's Avatar
Just curious, what is it being removed?
For myself, I'm a stickler for a clean rear end (cough) and am actually thinking of pulling the fuse on the wing lift actuator...
Old Apr 22, 2022 | 09:37 PM
OzXFR's Avatar
The bolts/screws in question hold down the cover over the spoiler motor which you have to remove to get at the wiring plug to disconnect the motor so as to permanently disable the spoiler, see here: https://www.jaguarforums.com/forum/f...5/#post1614196 in particular Step 7.
Don't pull that fuse, it is used for something else as well as the spoiler motor, something vital but I forget what atm.
Edit - in the thread I link to above there are two pics showing what you need to see, at post # 72 (the tray/cover still in place but with the 11 screws removed) and post # 81 (the wiring plug).
And one FM reported that the spoiler fuse also operates the Dynamic/Snow mode switch (he erroneously calls it the Sport switch) and that is why you don't want to remove that fuse.
Old Apr 22, 2022 | 10:37 PM
kb58's Avatar
Redundant post...
santacruz11
Mar 30, 2022 07:56 AM
Pistnbroke
Feb 17, 2022 03:57 AM
Hogger
Canada
Dec 15, 2020 07:08 AM
Jager17
Jul 21, 2017 04:00 PM
