Tune and pulley on a v6s
Old Aug 20, 2021 | 10:27 AM
George05's Avatar
Default Tune and pulley on a v6s
Asking for a friend my buddy joe I had done the supercharged oil change on his car a while back . Joe is asking me about getting his tuned and doing the pulley change also , if any one could give details on "how to " and what performance figures this would produce , car is a 2014 model , thanks George
Old Aug 20, 2021 | 10:55 AM
frank barone's Avatar
That's a great question, I would like to know the performance figures comparison to stock also. We know the horsepower gains for the V6 and the V,8 70 hp but we haven't seen performance figures 0-60 and top speed. I've seen top speed from owners on the Autobahn, very impressive for stock motors.
Old Aug 20, 2021 | 11:21 AM
Mahjik's Avatar
IMO, looking at numbers will just disappoint. If the owner wants more performance, do it and enjoy the "feeling". However, when you turn those "feelings" into data, it tends to underwhelm and what once was a good feeling no longer is...
Old Aug 20, 2021 | 12:25 PM
George05's Avatar
Information I can gather so far is a tune puts on extra 20bhp and 50nm of tourque, but don't know about the pulley , is it the supercharged or the crank pulley ? Thanks
Old Aug 20, 2021 | 02:24 PM
Obi's Avatar
Obi
HP and Torque will both be around 450 with tune and crank pulley
Old Aug 20, 2021 | 02:42 PM
George05's Avatar
On a v6s , that's amazing . What is the best pulley the crank or the supercharge ? What are costs like for the pulley ? Tune can be done for around £250
Old Aug 20, 2021 | 02:54 PM
J444G's Avatar
This was beaten to death if you use the search button.
Old Aug 20, 2021 | 03:03 PM
Obi's Avatar
Obi
See above.
Id recommend checking VAPs website for further information
Old Aug 20, 2021 | 03:56 PM
George05's Avatar
cheers guys
Old Aug 20, 2021 | 04:10 PM
I’m going to answer my own question, it’s comparable to the f type 450; 0-62 4.6 seconds 177 top speed..
Frank
Old Aug 20, 2021 | 04:31 PM
scm's Avatar
scm
DAE is the go to man in the UK for VAP stuff.
Old Aug 20, 2021 | 04:50 PM
lizzardo's Avatar
It's the crank pulley. The supercharger one is already pretty small.
Pour up a pint and sit down with this thread:
https://www.jaguarforums.com/forum/f...8s-v8r-158091/
You may need a second pint to get through it all, but you'll soon get a feel for where the real data is and what posts to skip.
Old Aug 20, 2021 | 06:29 PM
RGPV6S's Avatar
This thread is a "How To" for the crank pulley installation:
https://www.jaguarforums.com/forum/f...pulley-179588/
For a V6 with an auto transmission you will need to hold the crank from turning to loosen and reinstall the crank pulley bolts. I used a rubber strap wrench on the OEM pulley but you can use the large bolt/nut at the center of the inner crankshaft pulley to keep the engine from turning. Also make sure you clean the crank pulley bolt heads/holes by chasing them with a die/tap or they will be very hard to reinstall easily.
Old Aug 20, 2021 | 09:46 PM
OzXFR's Avatar
For the basic HP and torque figures you should go to the VAP web site for the F-Type here: https://www.velocityap.com/product-c...ategory=f-type
Then you need to select engine, year, OEM lower pulley "colour", tune only or tune + pulley.
The basic figures are:
OEM/stock: 340 or 380 or 400 PS (referred to as HP on the site) and 332 ft/lb torque.
Tune only: 416 HP and 353 ft/lb torque.
Tune + pulley: 450 HP and 440 ft/lb torque.
In my experience the jump in performance "feel" (no figures) is greater going from tune only to tune + pulley than is the jump from a stock S (380 PS) to tune only, which I put down to the much greater increase in torque. Tune only increases the torque by a fairly meagre 21 ft/lb but tune + pulley increases it by another 87 ft/lb on top of that which is yuge!
Old Aug 21, 2021 | 01:15 AM
George05's Avatar
Thank you kind sir , I shall read that thread tonites with a beer or two
Old Aug 21, 2021 | 01:22 AM
George05's Avatar
Many thanks Kim , I had an idea you had yours done , I shall pass this information on to my buddy , I am sure he would be happy with just the tune , as you say would eliminate the slight hesitation issue
TAEUCK Goo
Feb 4, 2022 01:17 PM
Cwmills55
May 11, 2021 03:17 PM
ESmcjagger
XF (X260)
Jul 29, 2019 07:40 PM
V8S
Jul 30, 2018 11:45 AM
Cherry_560sel
Feb 1, 2017 02:17 PM
