TVS2300 now Available from Harrop for AJ133S 5.0 Supercharged Engines
Old Aug 11, 2023 | 04:41 PM
GaiaXF-V8S's Avatar
Default TVS2300 now Available from Harrop for AJ133S 5.0 Supercharged Engines
Looks like a TVS2300 is now available for the AJ133S 5.0 Supercharged engines.
https://www.harrop.com.au/products/s...roduct_id=1128
Posting this all over the forum for exposure.
Old Aug 11, 2023 | 06:24 PM
Ray Ray's Avatar
How much more horses?
Old Aug 11, 2023 | 07:56 PM
OzXFR's Avatar
None!!
But that's with the stock upper pulley and tune, obviously much more available with a smaller pulley and tune.
No mention of a larger crank pulley.
Go to the linked page then download the Tech Guide.
Note that the linked page is to Harrop AU but the same SC upgrade kit is available from Harrop USA for $5,700 USD, see here: https://www.harrop-usa.com/jlr-aj133...ercharger/p151
Old Aug 11, 2023 | 09:51 PM
Ray Ray's Avatar
Looking forward to see what's people do with these, 700hp should be reasonably attainable, more than that will probably be much more involved.
Old Aug 12, 2023 | 01:59 PM
Ricky5.0s/c's Avatar
the stock blower is capable of 800+
Old Aug 13, 2023 | 07:52 AM
Unhingd's Avatar
Yes, but the 2300 will be able to generate that power for much longer periods without overheating the IAT.
Old Aug 13, 2023 | 08:42 AM
clubairth1's Avatar
Community Influencer
OzXFR that's what puzzled me too?
The dyno plots don't show any improvement?
I expected to see some increase with stock pulley since the 2300 moves more air?
On the Oz site it says $4200 USD but then no mention of shipping and I guess it must be purchased from the US vendor?
Old Aug 13, 2023 | 03:37 PM
Moniker's Avatar
I'd like to know if the 2300 is running the same psi boost as the 1900. I'd expect the 2300 to run less boost to make the same power as stock
Old Aug 13, 2023 | 03:50 PM
Moniker's Avatar
This video answers my boost question. Harrop is running a larger pulley to keep the boost about the same as OEM
Old Aug 13, 2023 | 07:18 PM
OzXFR's Avatar
Originally Posted by Moniker
This video answers my boost question. Harrop is running a larger pulley to keep the boost about the same as OEM JLR AJ133 V8 | Harrop TVS2300 Supercharger - YouTube
Near the end of the vid he says that VAP are working on hardware (pulleys and belts I guess) and tunes for this so I expect to see something from VAP very soon!
Maybe VAP will also act as an agent for this SC, ie we will be able to buy/get it from VAP with tune/pulley(s)/belt/tensioner packages?
Edit - I should have read one thread up before opening my big trap!
Old Aug 14, 2023 | 08:28 AM
Stuart@VelocityAP's Avatar
You're spot on. We will be distributing these chargers, and will be offering all the supporting mods required to make more power, in a couple of stages. Ultimately this is probably not going to replace pulley/tune combos for most people with the 1900, but will be for those who want to go a step further and/or will make sense as a bolt-on replacement for those with a worn out stock blower.
There were a couple more things than we initially thought that require hardware solutions, but we've been working at this for a little while now
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Aug 14, 2023 | 09:30 AM
clubairth1's Avatar
That is great to hear and I am looking forward to seeing what develops!
Old Aug 20, 2023 | 02:37 PM
ThunderKitty's Avatar
Timing is everything. I am shopping for an F Type now and had already been on VAP's website building a must have list. I'll be keeping a eye out for this. I would love to see 700-750hp out of the R/SVR.
Old Sep 12, 2023 | 09:45 PM
Ondatrack's Avatar
Old Sep 12, 2023 | 09:55 PM
Ondatrack's Avatar
I am sorry I accidentally posted this pic by accident and I cannot figure out how to delete it.
Old Sep 12, 2023 | 11:09 PM
OzXFR's Avatar
Originally Posted by Ondatrack
Hmm, a Pontiac GTO.
Really a tizzied up Holden Monaro built in Oz with LHD then exported to North America.
Old Sep 12, 2023 | 11:24 PM
Ondatrack's Avatar
Hmm, a Pontiac GTO.
Pretty much sums it up. Then I added a couple of turbos and spent money trying to turn it back into the Holden Monaro, minus the RHD.
Old Sep 13, 2023 | 01:29 AM
OzXFR's Avatar
When I was a kid the 1972 HQ Monaro GTS 350 was my dream car but out of my reach then.
Of course now a good one is even further out of reach, they can go for upwards of $500,000 if you can find one.
Here's one in good nick just down the road from me going for a snip at 400k: https://www.carsguide.com.au/car/132...mile-end/coupe
Old May 13, 2024 | 04:07 AM
conmao's Avatar
Default TVS2300
As usual the team at Harrop have done a remarkable job designing a direct replacement charger using larger Eaton rotors and in house housing to achieve a 2300. Looks great once you have one in your hands.
The full potential will be maximized once both lower and top pulleys are installed. Boost levels should be 15-17psi. As for HP well it’s all about getting extra fuel to the DI pumps and keeping the air intake temp down. And that’s if you get the tune correct so no piston is damaged in the process. Pistons in my opinion are the weakest link given they are cast however a safe tune and they should hold up, fingers crossed. Ohhh and lets not forget the head gasket, granted its MLS however open deck blocks don't help either. Ill keep everyone updated as I start my install soon.
Old May 13, 2024 | 03:30 PM
boost pressure has nothing to do with how big the supercharger is. You can have a massive 3.0 whipple making 20psi and a little 1.7l blower making 10psi and still make the same power. It all comes down on how efficient the engine is how much air it can flow. Why are people upgrading to a tvs2300? The 1.9 liter is capable of over 800+whp the 1.9 is a little badass blower if you what I'm talking about.
