tyres for ftype coupe s
Old Mar 21, 2015 | 08:50 AM
ScoopusMaximus's Avatar
Default tyres for ftype coupe s
Can anyone confirm the standard tyres used on the f type coupe s 2016 model. Struggling to find this Ingo. reasearch suggests michelin pilot supersports would be ideal. Any thought? Thanks. Oh....1st May confirmed as pick up date at dealers!
Old Mar 21, 2015 | 09:18 AM
gatekeeper's Avatar
Go to this site, at the bottom of the page, use shopping tools, contact us, and ask them.
Jaguar F-TYPE | Overview | Jaguar UK
Old Mar 21, 2015 | 09:23 AM
Schwabe's Avatar
Most supercharged V8S come with Pirelli P Zeros. Some, like an XF SC come with a Conti.
Old Mar 21, 2015 | 09:29 AM
StealthPilot's Avatar
I don't believe Jaguar has a contract with Michelin, I have never seen a new Jag with Michelin tires.
Old Mar 21, 2015 | 10:06 AM
Unhingd's Avatar
Both the 19" standard and 20" optional tires for the 2015 V6S Coupe are Pirelli P-Zeros. It is unlikely they will change for 2016. Mine will arrive with the 19" Propeller wheel and I will immediately swap with a set of Mich PSSs mounted on 20" Black Diamond Cut Gyrodynes (not available as a factory option on the V6S)
Old Mar 21, 2015 | 03:29 PM
gatekeeper's Avatar
Remember the OP is from the UK, not the states which may be different.
Old Mar 21, 2015 | 05:14 PM
Foosh's Avatar
Thus far (14-15 MYs), all the tires for each model have been the same on UK cars and those shipped to the US, Canada, Australia, and New Zealand. We've also had other countries represented here including Germany, Croatia, and UAE.
Old Mar 22, 2015 | 04:22 PM
F-typical's Avatar
The UK Configurator last summer allowed you to spec Michelin PSS on 20" rims in place of the Pirellis. Not exactly competitively priced though.
Old Mar 23, 2015 | 06:05 AM
OzRisk's Avatar
I found myself at the tyre shop today... Managed to dodge a bullet and have my rear right tyre repaired after they pulled a six inch nail out of it - a $30 repair instead of an $850 replacement tyre!
While I was waiting, I asked the guy what he would consider as a replacement, as I find the P Zeros skittish and hard to get the power to the ground.
Without hesitation, he said "Michelin Pilots", then added, "but they aren't cheap!"
Old Mar 23, 2015 | 06:27 AM
Foosh's Avatar
On high performance tire preference, the answers one gets are as close to unanimous as anything I've ever seen on a car forum. Right now, the PSS is the runaway first choice among car enthusiasts as the best street, extreme performance summer tire.
Old Mar 23, 2015 | 06:35 AM
Stohlen's Avatar
Which I have never really understood. I always felt they were just a mediocre performance tire. Going to the track with them isn't exactly wise, as they tend to start crumbling at the outside edge when driven hard. I've always felt Dunlop Direzza ZIIs and Yokohama Neova AD08s were a better street/occasional track tire. Only issue is the limited sizes available.
Old Mar 23, 2015 | 06:36 AM
DuhCar's Avatar
Chinese state-owned China National Chemical (ChemChina) is to buy Italian tyre maker Pirelli in a deal which values the firm at €7.1bn (£5.1bn).
The move is the latest in a string of takeovers in Italy by cash-rich Chinese buyers.
---> Oh boy, folks don't like our Pirelli's now .............
Old Mar 23, 2015 | 06:41 AM
Foosh's Avatar
I guess I don't either unless things have changed. I've had both of the models you list above and was extremely impressed with both. The Yokos were the best sticking tires I've ever had on any car. I weight grip and predictability above all else. Tire noise and all other factors are way down the list.
Old Mar 23, 2015 | 06:51 AM
The PSS is not an extreme performance tire. It is a max performance tire (one notch below). The Yokos will give you more grip for sure and if you look at Tire Rack tests it has better lap times wet and dry. However ride quality, noise and overall lifespan for a road car user can't come close. You won't get 20-25k miles out of the Yokos. Many people have out of the PSS.
Plus the only choices for those of us in the R Coupe are the P Zero and the PSS. Only two tires in OEM size for this car.
Old Mar 23, 2015 | 07:11 AM
Foosh's Avatar
Yes, I understand that, and I mistakenly used the term "extreme," but I meant "max performance summer." Actually, there is another choice, ContiForce Contact, which is the most expensive of the three, and it is listed as "streetable and track performance," with a wear rating of 80 vs. 220 and 300 for the other two. It surprises me that there aren't options available from Dunlop and Yoko.
I'm running the same 20" OEM sizes on my base. As I said above, grip is the number one consideration for me, with everything else (including tire-wear) running far behind.
Old Mar 23, 2015 | 09:14 AM
Yes, I understand that, and I mistakenly used the term "extreme," but I meant "max performance summer." Actually, there is another choice, ContiForce Contact, which is the most expensive of the three, and it is listed as "streetable and track performance," with a wear rating of 80 vs. 220 and 300 for the other two. It surprises me that there aren't options available from Dunlop and Yoko. I'm running the same 20" OEM sizes on my base. As I said above, grip is the number one consideration for me, with everything else (including tire-wear) running far behind.
Grip is number one for me too but wet weather grip is just as important as dry grip. This is the issue I have with the category of street able and track performance is that they tend to be susceptible to aquaplaning.
Last night I was driving through heavy rain on single lane country roads with large puddles and the Michelin PSS did an amazing job of cutting through the puddles while maintaining grip. It was quite enjoyable in fact.
Old Mar 23, 2015 | 02:40 PM
DuhCar's Avatar
+1 for wet weather grip. I'm a little worried that the Pirelli's aren't very good at it.
Old Mar 23, 2015 | 02:54 PM
Mahjik's Avatar
It's all relative... Are they as good as the PSS in the wet? Probably not. Are they better than some inexpensive Cooper tire? Yes.
DFW
Jul 27, 2020 02:44 PM
christophcr11
Oct 1, 2015 01:59 PM
AnD3rew
Sep 26, 2015 06:06 PM
redgear
Sep 26, 2015 07:21 AM
