Upgrading 200mm Door Speaker Clarification
Old Apr 12, 2022 | 02:04 PM
gershon's Avatar
Default Upgrading 200mm Door Speaker Clarification
Hi all, I'm about to upgrade my current 2014 f-type 775 Meridian sound system speakers with the upgraded Meridian Signature versions (from Land Rover). I've read all the informative posts, but seem to get hung up on one detail:
The 200mm door speakers I currently have seem to be 2ohm, but the upgraded LR047119 200mm Meridian Signature speakers seem to be 4ohm.
It seems others have done this upgrade successfully, and the sound quality has been significantly improved.
But, I just want to make sure going from 2ohm to 4ohm won't be an issue, or assuming my info is inaccurate, confirm what the correct ohms are.
Many thanks
Old Apr 12, 2022 | 09:05 PM
TH3FRB's Avatar
This is correct. With a digital amp it's likely adjusting for the impedance difference. Even if it isn't everyone reports the results are good so don't worry.
Old Apr 12, 2022 | 09:50 PM
gershon's Avatar
Thank you for the quick reply. I’m looking forward to completing this project.
Old Apr 13, 2022 | 05:40 AM
gershon's Avatar
I found the post that got me worried about using the 4ohm Meridian Signature mid bass speakers:
https://www.jaguarforums.com/forum/f...6/#post2400935
Old Apr 13, 2022 | 07:53 AM
clubairth1's Avatar
Community Influencer
Yes I did this in my 2014 XJ. You are correct about the different ohm ratings of the speakers.
I noticed no problems and thought the reference Kevlar drivers did sound better to me.
Old Apr 13, 2022 | 03:47 PM
gershon's Avatar
Hi all, thanks for the feedback, despite the stock mid-bass speakers being 2ohms, I went ahead and ordered the 4ohm LR047119. I'll give an update after I install them.
Also, I found these speaker adapters which were made from a mold of the LR047119, which I may buy just to see what else would work in the doors...I just can't figure out what size speaker would fit with them, 6.5"? 8"? EDIT: looks like the size is in the title, 6.5", sigh
https://soundsgoodstereo.com/product...-rear-one-pair
Old Apr 14, 2022 | 03:36 PM
Michael211's Avatar
Some have reported poor sound due to a mismatch between the speakers installed and the version of the Meridian software installed by the factory in their cars. This makes me ask whether we know that the installed software will work well with changed speakers.
Old Apr 14, 2022 | 07:12 PM
gershon's Avatar
@Michael211 thank you for the comments - I feel like I remember reading something like what you're referring to, but I can't seem to find it. It would be great if the people that have specifically installed the upgraded 200mm midbass speakers (LR047119) could chime in. It seems universal that the tweeters and 100mm speakers are a great upgrade, just the 200mm is in contention.
I've ordered the speakers, and just received an update this morning that they'll be here in a few weeks.
Old Apr 14, 2022 | 07:25 PM
Borbor's Avatar
it is the other way round, tweeter was said to be a bit harsh in most reports
Old Apr 15, 2022 | 08:17 AM
clubairth1's Avatar
Yes I did NOT change anything except swapping to the reference speakers with Kevlar cones. I did not touch any of the small speakers. I replaced all 4 door speakers and the 2 in the rear package shelf. They were all 200mm I believe?
Old Apr 15, 2022 | 08:19 AM
gershon's Avatar
@clubairth1 have the new speakers made a difference in the sound? better or worse?
Old Apr 15, 2022 | 08:29 AM
clubairth1's Avatar
My "old" ears thought there was a nice improvement in the bass and the sound is less strident when turning up the volume.
If must slam pretty hard because I can feel my pant leg fabric getting moved slightly by the bass coming out of the drivers door when at high volumes.
One thing I have noticed over the years playing with car stereo's is the very top end ones don't appear to play all that loud. But they do and I think it's about how fatiguing the system is caused by different types of distortion. I really notice this more in home computer speaker setups. Plenty of them play very loud but I can only listen a few minutes before I turn them down.
I do have a 2014 XJ so not the exact same car but all the hardware is very close. I can't answer about the digital software versions either as I don't know what version I am currently running?
That could certainly make a huge difference.
Old Apr 15, 2022 | 09:04 AM
scm's Avatar
scm
The XJ is much more of a concert hall than the F-Type's cabin!
Old Apr 16, 2022 | 10:21 AM
clubairth1's Avatar
Very true so I wanted to note that as well!
Old Apr 20, 2022 | 03:01 PM
Jag Bass's Avatar
The Signature Meridian 200mm will be more controlled and less boomy than the 380w or 770w systems which both have the same speakers. They will play a bit quieter with the factory amp now running at 4ohm vs 2ohm on those channels so less power is created from the amp but they still sound good. I would however recommend an aftermarket amp that can accept high level speaker inputs at least 75watts per channel @ 4ohms. If you go that route remember you will need load generating devices between the factory amp and aftermarket amp.
Jag Bass
Apr 12, 2022 06:21 AM
XJLFTW
Aug 13, 2021 02:15 PM
rexus31
Aug 17, 2018 03:46 PM
Sam1
Nov 5, 2012 07:13 PM
