Upper mounts worn out has any one seen this before
Old Sep 29, 2023 | 02:56 PM
RichardCranium's Avatar
Default Upper mounts worn out has any one seen this before
Hit a giant pothole and the car started feeling like the front passenger shock had blown. Took it on the dealer and was told the upper mount was worn out I took a look under the hood and saw this. It's the same on both sides looks deteriorated.
2106 f type r 20000 miles lowered on h&r
Old Sep 29, 2023 | 04:55 PM
cpq100's Avatar
That looks like organic material to me. Could a mouse have gotten in there and made a home?
Old Sep 29, 2023 | 05:07 PM
Thunder Dump's Avatar
Unfortunately yes. The material disintegrates with age, apparently. Check out this thread--you'll see a surprisingly similar photo:
https://www.jaguarforums.com/forum/f...shings-262262/
Old Sep 29, 2023 | 06:16 PM
Thank you! That's exactly what it is.
Old Sep 30, 2023 | 11:35 AM
clubairth1's Avatar
Community Influencer
Yes this exact same thing happens on XJ's as well. The real key is the crumbles from the disintegrating foam.
As it gets worse you can see the shaft will start to move from the center position to one side or the other.
The thread posted above also has a good picture of when the shaft starts to get miss-aligned and pushed over to one side.
ccm93
Dec 10, 2023 06:54 PM
srpope80
Aug 24, 2023 02:30 PM
Johnken
Oct 8, 2022 10:00 AM
rackets351
Jan 20, 2021 07:46 PM
wymjym
Feb 10, 2020 10:51 AM
