VAP Pulley install how hot to get the pulley
Old 06-04-2018, 12:41 PM
ntbrinkl's Avatar
Default VAP Pulley install how hot to get the pulley
Hey trying to get this pulley on. Had it in my toaster oven at 350 for 25 min. Went out and it didnt hardly want to start on there. I did a harmonic balancer hub on a crankshaft on a dump truck and that thing slid right on like butter. Any ideas? Im going to crank the heat up to 450 and see what happens.
Also there is a rubber seal there from the bearings. I have not hear anyone talk about this being a problem melting. Should I be worried?
Old 06-04-2018, 02:41 PM
Unhingd's Avatar
Received 4,652 Likes on 3,362 Posts
Before giving too much guidance, are you trying to install the upper pulley on the V8?
Old 06-04-2018, 08:01 PM
ntbrinkl's Avatar
Yes sir, upper pulley on the V8. No performance shop around me willing to do it.
Old 06-04-2018, 09:07 PM
Unhingd's Avatar
OK...first take some Emery Cloth lightly to the shaft to ensure it is perfectly smooth. Removing the old pulley might have left some very minor scoring. Regarding the oven, crank that bad boy up to max, maybe even broiler setting with the door closed. If the aluminum pulley is sufficiently heated to slide on, the steel shaft will easily absorb the heat without the temperature rising too much for the seal to handle. The specific heat of steel is twice that of aluminum, so that shaft will not even get close to a temperature that will endanger the rubber seal. Use some form of spacer as a jig to properly position the pulley. You’ll get only one shot at sliding it to the right spot. Silicone oven mitts will be your friend.
RGPV6S
12-01-2018 03:07 PM
Cherry_560sel
10-25-2018 12:31 AM
2Cool
04-06-2018 07:43 AM
2Cool
03-01-2018 07:29 PM
C Rad
02-28-2017 12:04 AM
Quick Reply: VAP Pulley install how hot to get the pulley
