VelocityAP V6/V8 Headers Development
Old May 2, 2016 | 03:52 PM
Stuart@VelocityAP's Avatar
Sponsor
Default VelocityAP V6/V8 Headers Development
Hi Guys & Gals,
A few of you have messaged & emailed me about these. Good news is it appears that our local customer with a '15 V8 R will be dropping by on Friday, so we can have a poke around, see what the space constraints are and so on.
He's off on a Poker Run but we will probably see the car back in the shop not long after for development if it looks feasible.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old May 2, 2016 | 05:54 PM
Overblown's Avatar
That is huge news!
Old May 2, 2016 | 07:06 PM
Unhingd's Avatar
Originally Posted by Overblown
That is huge news!
I'd wager that availability is at least 2-3 months out. Development of all these aftermarket parts (headers, short shifter, CF engine cover, etc.) is painfully slow.
Old May 2, 2016 | 07:23 PM
Sponsor
That is fairly accurate. The 'development' in terms of designing and testing parts is not an enormous time frame, given that the packaging constraints on modern cars usually dictate a limited design envelope. You're not going to test 20 designs...
However, fabricating and manufacturing are two different things, so to create parts & jigs is one thing, but to then fit say, 50 parts into a manufacturing schedule, pattern all the component pieces etc. and assemble in a cost effective way, that's a different kettle of fish.
It always takes time, but as the saying goes, you can have it done fast, well, and cheap. Pick two.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 3, 2016 | 01:46 PM
Overblown's Avatar
Nothing wrong with that. Got to get it right the first time. The power increase should be sizable not to mention the sound improvement.
Old May 6, 2016 | 05:37 PM
Sponsor
Look what showed up today....
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 6, 2016 | 05:40 PM
Sponsor
Driver's Side is very tight.
Passenger side is much easier.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 6, 2016 | 05:44 PM
Sponsor
So, just looking at the V8, the passenger's side could accommodate a 4-1 design, but on the driver's side, the first runner is VERY close to a line. Think it was a PS line. When we have the car back, we will have to take a look and see if this is a flexible line that can be bend out of the way.
Even if it can, I don't believe that we would be able to run 1 7/8" primaries on that side in a 4-1 configuration. So it will most likely need to be a 4-2-1, 1 7/8" into 2" secondaries and then 2.5" collector, sport cat etc.
It's a challenge, but we can do it.
V6 may prove trickier still, but it might be possible to get 3 primaries out in relatively equal lengths compared to 4.
Car is most likely coming in 1st week of July, but we're going to try and work with the owner' schedule to get it done earlier than that.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 6, 2016 | 06:31 PM
Stohlen's Avatar
Now i'm sure you're aware of this... but of course Jaguar has made developing aftermarket exhaust systems very difficult. 14-15MY has hydraulic power-steering and 16MY+ has electric. Then there is the AWD to consider as well.
How do you plan to handle this? I am very excited about the possibility of AWD R long tube headers, but the market might not be there to make it worth while to you. If you think about it, you could potentially have to make 5 different sets of headers to cover everything just for NAFTA:
14-15 V8 models (hydraulic PS)
14-15 V6 models (hydraulic PS)
16+ V6 RWD (Electric PS)
16+ V6 AWD
16+ V8
Now hopefully the RWD V6 would fit across the board, which would bring the total down to 4. But would making 4 different sets of headers be worth while?
Old May 6, 2016 | 06:47 PM
Sponsor
16+ V6 AWD
16+ V8
Without having all the cars here at one time it's not possible to engineer a magic bullet with 100% certainty. For the PS setup, we can certainly try to work around the location of the Electric PS.
For AWD models, we do have on hand reference downpipes which clear the AWD bracket but this clearance difference is actually on the back end of the downpipe. The downpipe section can be made to fit all if the flange location is in the right spot. The main clearance difference on the AWD is that the driver's side catalyst is actually oval rather than round, so again, if we build off this car by assuming that there is limited clearance in that spot we can probably engineer around it.
Now.... LHD/RHD I am not so sure about. But again, you can sort of eyeball the location of the steering column and rack attachment and pretend that it is there....
The question is not what can be done, but more so whether it can be done in the 10 day window we have with the car. And I'm sure no matter what we do, that there will be a couple of 'need to check one on X variant' and see before we get it all figured out.
If it was easy, everyone would be doing it. So if we can engineer a solution such that there is 1 V6 Header, 1 V8 Header and 1 downpipe that mates up to both we can rationalize production enough to probably get a V8 Header + Sport Cat Downpipe into the $3500-4000 range. The more they can be made the same, the more economies of scale takes over.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 6, 2016 | 07:07 PM
Cambo's Avatar
Stuart,
If you have to make a 4-2-1 design then please, please, please make the branching like this:
https://www.jaguarforums.com/forum/g...-2l-s-c-80560/
See the comments from Count Iblis (you know who he is and his background).
Old May 6, 2016 | 07:21 PM
Sponsor
I hadn't got as far as the firing order to see which cylinders would need to be paired with which, but it looks like it's the same as the 6.3L AMG V8. We just finished developing a set of headers for the SLS AMG Black Series. A lot more room with that car, but required some contortion to equalize the runner lengths perfectly:
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 6, 2016 | 07:44 PM
Smoke Em's Avatar
Wow... Those are beautiful!!! Thanks for those pictures.
Old May 6, 2016 | 07:46 PM
Sponsor
Originally Posted by Smoke Em
Wow... That is tremendous and beautiful!!! Thanks for those pictures.
You should hear it.
Has our 2.75" XPipe exhaust with 2 tiny silencers. When you downshift at higher RPM it doesn't even sound like an engine, just sounds like an explosion.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old May 7, 2016 | 01:48 AM
cbroth1's Avatar
Wow, somebody knows how to TiG weld.
Old May 9, 2016 | 10:37 AM
Sponsor
It's not me, I assure you.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jun 23, 2016 | 08:03 PM
Unhingd's Avatar
Default L.T. Header Status
Stuart,
What is the status of development for the long-tube headers? Of course, I'm particularly interested in the V6 version.
Old Jun 25, 2016 | 11:39 PM
ss23's Avatar
Stuart,
+1. Am really looking forward to these!
Old Jul 1, 2016 | 04:19 AM
Sponsor
Just chatted to my friend. We were aiming to have the car in this week, he's had a tempting offer trading up on an SVR so a bit up in the air on timing. But should still get rolling soon.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Sep 15, 2016 | 12:49 PM
Sponsor
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
