VelocityAP ZF8HP70 Transmission Tuning (TCU)
Old Feb 15, 2022 | 01:20 PM
  #121
Andi Jaguar G's Avatar
Originally Posted by Tuning@VelocityAP
Andi, you started communicating over email this weekend and now you've brought this to the forums. Unfortunately, I do not monitor the forum often and leave most replays done from sales, posting to the forum site is going to delay a response and solution from our technical team.
Nonetheless, lets bring everyone up to speed...
As mentioned in my email and I'll say it again. Regardless of what anyone else has sated..Our JLR TCU tune paired with our Engine tune bumps 500rpm...
The stock limit is indeed 6500rpm, it also has a "softcut" rpm limit that enables +200rpm if particular conditions are meet..which means 6500rpm+200rpm = 6700rpm on the stock tune.
Our early TCU tunes bumped to 7500rpm, but we decided after much testing that no power was left in that range in low gears to provide any benefits. Avoiding the need to short shift in lower gears to increase trap, the call was made to drop to the 7,000rpm range and cancel the softcut to 0rpm, that way 7k is the max possible under power.
There's also some calibrations that have the stock limiter set in all modes except Dynamic which is bumped to the 7k, that is because they were superseded versions that HPTuners did not have the option at the time to edit those map fields..aka, dynamic mode only had the rpm bump.
In reply to your concern of skipping gears, I informed you I don't understand your testing and I needed something more than what you proved of a quoted time taken to accelerate. Being you have one of our datalogger tools, I simply advised to record a datalog of your concern and I would investigate to see if the trans is indeed skipping gears and what could possible be related to you slower time.
Maybe it's my misunderstanding, but I really don't know what more you want me to offer you, to help resolve your concerns with our product.
Christopher, you are doing a great job and I am very happy with the support. If the 7000rpm fits, then that's all fine with me too. It is therefore not clear why I had this 50% less power. But that will show up in the log file. I don't expect any additional support. For me it all fits very well. As soon as I've completed the tests, I'll get back to you via email, and only via email this time, I promise. Thank you very much for everything...
I can understand that my first test 100-200 km/h is not easy to understand. In simple terms, it was: Automatic mode S, full throttle at approx. 60 km/h. Car always shifted at 7,000rpm. At 160km (should have been 3rd gear) after shifting the power was around 50% and the speed increased linearly to 200km/h, but noticeably slower than usual. It felt like I wasn't in 4th gear. gear, but rather drive full throttle in 5th or 6th gear after 3rd gear. And then I measured about 11 seconds at 100-200 km/h. instead of 7 seconds. But that doesn't really matter now, we can't get to the cause without a log file anyway. Thanks so much...
And yes, the TCU and ECU Update is nice, what a diff. to the OEM Shift, I love it... Please understood me not wrong!
Old Feb 16, 2022 | 12:47 PM
  #122
gearFX's Avatar
Does the ECU tune alone (no TCU) modify the shift RPM or redline too? Or these changes only occur when adding the TCU?
Old Feb 16, 2022 | 02:35 PM
  #123
Tuning@VelocityAP's Avatar
The stock engine limiter is 6800rpm, the stock tcu limiter is 6500rpm (on the ZF8 cars).
With the above in mind; If I edited the file to raise the engine rpm to something like 10,000rpm, the TCU would still command a shift at 6,500rpm.
---Small advisory, there's certain calibration floating around from JLR that enables the paddle mode to bump off the limiter. Thar's because the limiter in the TCU file is set at 9,000rpm(in paddles only) while the engine is set to 6800rpm. In most of the JLR fleet, this is not the case though and the TCU will only allow 6500rpm to be reached.---
On another note, what I do in the engine tunes for the rpm limiter without the addition of a TCU tune, I raise the park/neutral limiter from 4,000rpm to 6800rpm. Not that we recommend revving the engine with no load, but if you wanted too, you could rev past 4k..
If the car was a manual shift like some of the 3.0L F-Type's, they obviously don't require a TCU tune and only editing the engine tune would allow for a higher rpm range.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old Feb 16, 2022 | 03:12 PM
  #124
ToysARs's Avatar
Is it possible to do TCU tune without ECU tune for the objective of increasing paddle downshift and upshift speeds/crispness without raising the rpm limits? Faster paddle downshifts and upshifts would be the only improvements I would want to have with the ZF8.
Old Feb 16, 2022 | 04:12 PM
  #125
Sure, it's totally possible. But you would need to note that request in the tuning submission form. (aka..to keep the rpm stock). Otherwise the tcu shift rpm request would be bumped to 7k by default.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old Feb 16, 2022 | 04:45 PM
  #126
ToysARs's Avatar
Just to confirm, TCU tune can be installed without the ECU tune as long as RPM limits are not changed, correct?
Old Feb 16, 2022 | 04:56 PM
  #127
Correct
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Old Feb 17, 2022 | 01:28 AM
  #128
Originally Posted by Stuart@VelocityAP
At the moment we are increasing by 200RPM. Any time you push for more performance you can accelerate wear rate on your components, but we feel this is still pretty safe.
I also think of the number of questions and discussions here, the topic is simply more complex for a normal F-Type driver than expected. :-)
I was too confused by this original statement from VAP, sorry again. After this post, it was clear to me that my cat effectively has +200rpm
after the TCU and ECU tuning. However, the following limits are currently stored (hopefully I understood it correctly!), and these +200rpm
are not found there. Hence my stupid questions.
TCU:
OEM 6500rpm
VAP 7000rpm (initially 7500rpm)
ECU:
OEM 6800rpm
VAP 7500rpm
And I could never find my mentally anchored +200rpm in these numbers :-) Well, that should have been it for this topic :-)
Nice week...
Old Feb 20, 2022 | 02:45 PM
  #129
gearFX's Avatar
Thank you so much, you've answered my original question and even anticipated a few I might have asked after reading your initial response.
Old Feb 20, 2022 | 02:53 PM
  #130
gearFX's Avatar
My calculus is rusty so I'm not qualified to compare "area under the curve" for the different dyno charts of ECU gains vs. TCU gains vs pulley gains, but is one of the 3 a "better" value (bang for buck wise), because it's offering the most performance in an accessible RPM range? (For example, I imagine a pulley alone or ECU alone may increase performance or power output across the meat of RPM range, but a TCU tune alone only buys you higher output otherwise not available but only for a few hundred RPM at the top end right?)
Also, is one on the 3 options considered to be "safest" from a reliability standpoint (in terms of exceeding original JLR design or engineering limitations the least)? Or how would you rank them 1,2 and 3 in this measure from a mechanical sympathy standpoint?
Old Feb 20, 2022 | 09:17 PM
  #131
Therock88's Avatar
You can run the ECU Tune alone, or the TCU Tune, but you CANNOT run the Lower Pulley alone without an ECU tune, so that is not an option. Likely best bang for the buck is ECU tune alone, if you are looking at minimalist solution. I would think the TCU tune would be least likely to push the car to engineering limits ….Just an opinion. Depends a lot on your goals. Safest bet is to do nothing...then it is a continuum of performance and risk trade-offs.
I have them all, and I am happy with the setup. I do not spend time worrying about warranty or repair costs...I just mod and enjoy the cars. If something breaks, I can always throw enough money/time/effort to fix it.
DC
Old Feb 21, 2022 | 11:27 AM
  #132
ToysARs's Avatar
DC
@Therock88, than you for all the information you have provided on this thread based on your experience with these products. Just curious, do you have any videos of you dash after the TCU tune? I'm really curious about the manual/paddle downshift and upshift speeds compared to the stock car (especially downshifts as in stock form, manual downshifts seem to be a second lagged).
Old Feb 21, 2022 | 02:15 PM
  #133
Therock88's Avatar
Sure...No problem. Unfortunately...I am not a YouTuber, and take very few videos of anything I will say that the adjustments made to the shift strategy are noticeable. While this type of thing is very subjective to describe...When I press the paddle (up or down) it shifts pretty much instantly. These ZF8HPs are used in a multitude of cars and they have lots of controllable variables based on what the car manufacturers want...VAP did a great job "optimizing" the shift strategy for this platform.
No videos however...Just a subjective review. I cannot even say I have looked at the shift points...It is just very fast/negligible delay!
DC
Old May 12, 2022 | 08:52 PM
  #134
EdG's Avatar
EdG
Posting to this tread but there might be a better one. I have a 2016 V6S with TCU tune along with crank pulley and ECU tune after the TCU tune (burble/pop checked). No issues in Dynamic mode, sport setting with paddle shifts, very fast and crisp with occasional burbles on up shifts, down shifts also fast (near perfect).
My issue is when in Dynamic mode, S setting allowing the car to shift itself, burbles more dramatic but seems like too much after the first gear or two. The shifts and burbles seem to take too long. Particularly around 75 MPH can be slow, too many burbles. Passing a truck earlier this week, the shift around 75 had several seconds of burbles, enough that I needed to let off the gas because it wouldn't shift. It makes me reluctant to push the car in this setting. I assume that the I can get a different tune. Just curious if my experience is unique. Not sure if I would need a new TCU or just a modified ECU tune.
Any thoughts?
Thanks!
Old May 12, 2022 | 09:46 PM
  #135
Therock88's Avatar
Any thoughts?
Thanks!
I am not sure what "burbles" means? I have not had any issues with mine shifting in any modes.
DC
Old May 13, 2022 | 03:10 AM
  #136
scm's Avatar
scm
Since the noise happens at higher revs, telling the car you want dynamic and S is giving it a clear message to use those higher revs, hence the noise you seem not to want. If you want it quiet, why use dynamic and S?
Old May 13, 2022 | 02:37 PM
  #137
EdG's Avatar
EdG
Sorry, I wasn't clear. It's not the noise that is the problem. It is that the car is not shifting while making all the noises.
Old May 13, 2022 | 02:46 PM
  #138
RGPV6S's Avatar
With my car if I put it in S and dynamic and start shifting with the paddles the car will stay in the selected gear until a paddle is pulled so you might be bouncing off the rev limiter under acceleration. If in S and dynamic and I never touch the paddles the car will shift on its own. The only exception is if you come to a stop and forget to downshift. In that instance the car will downshift. Maybe under acceleration if you continue bounce off the rev limiter the car will sense you forgot to shift and eventually do it for you. My car is a 2014 so things might have changed over the years.
Old May 13, 2022 | 02:50 PM
  #139
EdG's Avatar
EdG
DC
Are the shifts just as fast when using the paddles as when allowing the car to shift itself? Near full throttle the shifts are considerably faster when using the paddles compared to when the car is shifting on it own (i.e. not using the paddles). It tends to be highway speeds, particularly in the 70s MPH. I would like the shifts to be just as fast regardless if I am using paddles or not.
BTW. I can't remember what the VAP website calls it but I am referring to the box you check when getting the ECU tune that requests the noises that may damage the catalytic converters, but that is what I mean by the "burbles".
Old May 13, 2022 | 03:36 PM
  #140
I'm not sure I follow what you are asking, or if you are just raising a concern with the way Jaguar themselves have configured the stock sounds of your vehicle.
The "noise" you are referring to must be "pops and bangs".
However, the transmission has nothing to do with your engine creating these pops and bangs when your vehicle is deaccelerating.
If the pops and bangs(burbles) are a problem for you, then an engine tune could be created to remove them entirely.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
