Water Pump Replacement
Old Mar 4, 2019 | 07:48 PM
Mjet's Avatar
Default Water Pump Replacement
Is it replaced from the bottom or top on the R?
Old Mar 4, 2019 | 08:40 PM
addict's Avatar
Water pump is on the front and pretty easily accessible from the top — though the reverse hinge hood is really irritating on this job.
Old Mar 5, 2019 | 07:18 AM
Mjet's Avatar
Had water pump replaced last week. Coolant oder is still present and the plastic engine cover seems as if it has not been touched.........
Old Mar 5, 2019 | 07:47 AM
addict's Avatar
was it replaced at the dealer? mine washed the engine bay after so that the coolant smell would go away
are you concerned they didn't actually fix the problem? I ended up having an additional leak in one of the coolant lines under the supercharger which required it to go back under the knife a week or so later
Old Mar 5, 2019 | 09:28 AM
Chawumba's Avatar
Similar experience for me. Not even sure if they really replaced it. Mine holds pressure, and no drop in coolant, so I figure it can't be too severe a problem. I tried teflon tape on the reservoir cap, haven't noticed much improvement. Fortunately, this is the only issue I've had with the car, so I just live with it....
Old Mar 5, 2019 | 05:22 PM
Mjet's Avatar
Dealer. It just seems like the engine cover was not remove. Dust/dirt is even throughout with no fingerprints.... I will check real good under the cover this weekend. They had the car an entire week.......
Busa196
Jan 13, 2025 04:33 AM
Joe Gandalf
Oct 3, 2018 12:44 AM
SteveM
Oct 12, 2010 09:57 AM
AntixSD
Apr 3, 2010 07:40 AM
