Wheel Locks
Old Aug 15, 2018 | 04:28 PM
Unhingd's Avatar
Originally Posted by eeeeek
I think you just cleaned up both my glove box and my trunk. My tow hook was just showed under and elastic strap in the bottom well of the trunk.
I have not yet figured out what that particular elastic strap is for. There’s also another one in the back of the boot on the right hand side.
Old Aug 15, 2018 | 05:26 PM
Buckingham's Avatar
I bought the dome top locks. There is absolutely no clearance to to hammer a socket over them. You just need the key. It has a letter code. I wrote it down on a Jaguar card that also has a spot for your emergency key number, although there was no number sticker on either emergency key. My code is ‘W’ if I ever lose it. I will ask you guys for it.
Old Aug 15, 2018 | 06:20 PM
OzXFR's Avatar
On mine the strap at the LHS front of the boot/trunk/hatch was used for the goo kit compressor, but it was very soggy and pretty much useless so the compressor now sits in the cubby/box.
I find the little strap at the back RHS of the hatch to be very useful to store/hold my window frost wiper-offer tool (ie a small window cleaner) which I need most mornings in winter when leaving from SHMBO's joint, mainly for the rear window.
Old Aug 15, 2018 | 09:07 PM
Unhingd's Avatar
[QUOTE=OzXFR;1947440]On mine the strap at the LHS front of the boot/trunk/hatch was used for the goo kit compressor, but it was very soggy and pretty much useless ...QUOTE]Mine's getting a bit stretched out and weak as well.
Old Aug 15, 2018 | 09:33 PM
eeeeek's Avatar
Right in that same location along side the battery
I didn't see an obvious place for the tow hook. Perhaps I'm missing a piece? I clearly have the spot for the key and there is another spot for tire goo. The side of the battery are just open air until the walls.
Old Aug 15, 2018 | 10:13 PM
F-Envy's Avatar
Unhingd posted a great picture of the tow hook in it's carrier. I tried to copy and paste the picture for you but as I'm an idiot it failed in the preview. Find the thread "Group Buy: Lithium-Ion Battery" and look at post #125 (page 7).
Old Aug 15, 2018 | 10:36 PM
Unhingd's Avatar
Here's a pic of the hook sitting in the Styrofoam cradle:
Old Aug 15, 2018 | 11:36 PM
  #28
eeeeek's Avatar
Yep, I don't have that cradle. I'll search the web to find one.
Old Nov 13, 2021 | 02:34 PM
Nightshadow's Avatar
Originally Posted by Itismejoshy
BURN!! .LOL...but facts. the "jaguar" keys with the round dome are almost impervious to standard tire shop methods of removal (slamming a socket over it or using a gatorgrip socket). Ended up using the torch after drilling was ruled not to be an option (4+hrs of drilling and impact hammering did basically nothing) because of the "supermetal" (as the service tech came to call it) cap. i believe the McGard locks with the key notches on top and not the sides are easily removed by most tire shops using the method above. It was noted by the tech that he has never seen a factory rim hold up to heat like the jag rim did, was impressed with the lock and the rims. Minimal damage really.
i will be promptly removing my wheel looks, my car is locked up 99% of its life.
Wow, this is impressive. I am actually in the process of ordering Jaguar OEM Wheel Locks as I DO live in a part of the country where stolen rims and catalytic converter thefts are all the rage and happy to hear the Jaguar ones stand up to most forms of brute force attemps.
Old Nov 13, 2021 | 02:37 PM
  #30
Wonder if there's something similar for the F-Pace?
sandydlc
May 25, 2016 01:59 PM
TomServo
Apr 6, 2011 03:44 PM
mrbean1957
XJ40 ( XJ81 )
Jan 29, 2011 11:11 AM
edtexas
Dec 6, 2010 07:53 AM
