Wheel spacers
Old Aug 2, 2019 | 08:25 AM
xrix4096's Avatar
Default Wheel spacers
Hi all,
Have read lots of wisdom here about wheel spacers / adapters. Can anyone confirm whether these parts would be correct? It's to go with the 20" blades, stock geometry.
https://www.ebay.co.uk/p/H-R-2x15mm-...634/1965856292
Thanks!
-- Chris
Old Aug 2, 2019 | 08:36 AM
Itismejoshy's Avatar
Originally Posted by xrix4096
Hi all,
Thanks!
-- Chris
15mm is correct, 63 is the hub size, says they are hubcentric and H&R is reputable. May need to trim your studs a tiny bit, but i would just head over to the classified section usually a set or two listed. or find the group buy and give motorsports tech a call.
Old Aug 2, 2019 | 11:41 AM
Luc Lapierre's Avatar
Good news: blade wheels don't require trimming studs for 15mm spacers.
Old Aug 2, 2019 | 01:14 PM
good info!
Old Aug 2, 2019 | 06:48 PM
OzXFR's Avatar
Yep, I have Blade wheels and 15 mm spacers, no trimming required.
I have commented on this many times before but AFAICT the Blades are the only F-Type OEM wheels with big enough / deep enough recesses between the stud holes to take the original wheels studs with 15 mm spacers with no trimming of the studs or grinding/drilling of the wheels.
It's almost as though Jag intended those with Blade wheels, and only those with Blades, to fit 15 mm spacers!
Old Aug 2, 2019 | 07:41 PM
Poison Ivy's Avatar
At the risk of sounding dumb...what are the spacers for? Assuming to put f type wheels on non f type??
Old Aug 2, 2019 | 07:52 PM
OzXFR's Avatar
Rarely.
They are used 99% of the time simply to push the wheels out a bit so as to better fill the wheel wells and improve the "stance" and looks of the car.
To many the stock F-Type looks a little "knock kneed" with the wheels tucked too far under the guards.
Pushing the wheels out a bit may also improve grip and handling but that is debatable.
There is a lot of confusion between "spacers" and "adapters", particularly with hub-centric spacers often being called adapters.
I use the term adapters for those fittings which allow you to fit wheels with a completely different bolt pattern and/or PCD (Pitch Centre Diameter), for example see here:
https://www.ebay.com/itm/4pc-Wheel-S...gAAOSw5wNcN8rf
Old Aug 2, 2019 | 08:20 PM
Poison Ivy's Avatar
Originally Posted by OzXFR
Rarely.
Thanks OzXFR! That makes sense.
Old Aug 3, 2019 | 07:25 AM
xrix4096's Avatar
Thanks all for the great responses. I think I understand the specifications now so I'll keep looking. I've had a quick dig in the classifieds section on here but don't think I can see anything applicable (though I got a bit lost in there). The Motorsports-Tech ones look great but given that I'm in the UK they will end up a fairly expensive option by the time shipping is factored in so I'll probably keep trying until I can find something suitable in Europe.
Thanks again!
-- Chris
Old Aug 3, 2019 | 07:38 AM
xrix4096's Avatar
One more on the same subject: I'm assuming that people are using the same factory torque on the nuts (~92.2 lb/ft / 125NM) when attaching both the spacer to the car and the wheel to the spacer? I can't think why not but I know what they say about assumptions....
-- Chris
Old Aug 3, 2019 | 08:50 AM
Unhingd's Avatar
-- Chris
Correct.
Old Aug 3, 2019 | 08:59 AM
Unhingd's Avatar
Thanks again!
-- Chris
Wheels UK carries SSC spacers and adapters: https://www.wheelspacers.uk.com/inde...F-Type&typ=QQ6
I’ve used both SSC and Motorsport Tech adaptors and they are comparable quality. You’ll want SSC’s System 3 adaptor. Available in plain aluminum as well as black and silver anodized.
Old Aug 3, 2019 | 10:01 AM
xrix4096's Avatar
They look perfect and apparently are in stock. Order placed!
-- Chris
Old Aug 24, 2019 | 05:02 PM
xrix4096's Avatar
These arrived a few days ago and today I got around to fitting one of them (I know fitting one is a weird thing to do but I spent the whole day cleaning, dismantling and ceramic coating the wheel while it was removed from the car). They are really nice parts and work perfectly with the blade wheels without any modification to studs or anything. I've done one side on the rear and it's fun to look at the difference in stance between the spaced side and the stock - IMHO it looks so much better spaced out. I obviously haven't driven it yet as I prefer my wheels to be symmetrical but it looks like the 15mm spacing should still clear the bodywork without difficulty.
Thanks to all who helped on the thread. I'll post some pictures when I've done all 4 wheels ;-)
Miami XKR
May 1, 2010 08:27 PM
Jaggyx
Mar 23, 2010 02:00 AM
YaoNYC
Nov 3, 2008 09:22 PM
sempaipaul
Jan 28, 2007 01:47 AM
Apr 30, 2006 10:40 AM
