Window operation question
Old Jun 27, 2014 | 08:42 PM
pabanker's Avatar
Default Window operation question
Guys, my driver side window's "convenience" feature appears not to work fully: it doesn't automatically go all the way up when I do a full click on the button. What's weird is: (1) It goes all the way down no problem, and (2) the passenger side goes both all the way up and all the way down. Any one else have this issue? I can't find any setting in the "Systems" setting for this, so I don't think it's a set up issue. Appreciate anyone checking their car and letting me know if there's does (or does not) have this issue, or if anyone knows what the solution is... Feeling stupid.
Old Jun 28, 2014 | 12:43 AM
spinningbull's Avatar
That happens to me occasionally. Havent figured out what triggers it yet.
Old Jun 28, 2014 | 07:43 AM
nscott's Avatar
pabanker - The windows have a safety feature that will stop them from closing if they hit an obstruction. This can happen sometimes even during normal operation - when there is no obstruction.
The procedure to RESET the windows is in the Owners Handbook. Albeit the description is a little hard to follow. To reset the window, first open it all the way. Then using the switch on the door, hold the switch in the close position untill the window closes all the way. Don't release the switch after it closes. Keep holding it in the close position for a further 2 to 5 seconds. The window one-touch feature should now operate correctly.
For those who are interested, here is the write-up from page 140 of the US Owners Handbook:
Name:  Window Reset - p140.JPG
Old Jun 28, 2014 | 08:56 PM
pabanker's Avatar
Nscott it is not a window reset issue, but thanks. The problem is with the "convenience" feature. The driver-side window doesn't automatically go up when I fully engage its window button (ie, when the detent clicks). It's weird because the passenger side window works fine.
I am wondering if anyone else noticed this on their F Type. Or if there is some setting I'm missing in the car's Set Up.
Old Jun 28, 2014 | 10:07 PM
another_geek's Avatar
Actually, the symptom of a window needing to be reset *is* the disabling of the auto-up feature. The car no longer knows the exact position of the window glass, so to prevent damage, it disables the auto-up feature. Following the reset procedure above lets the car figure out the glass position. This is a common issue.
Old Jun 29, 2014 | 07:27 PM
pabanker's Avatar
Success! You were right, it was a window reset issue. Hilariously, right after I fixed the driver-side window, the passenger-side window started misbehaving. I reset that one too, of course, and now have two fully functioning windows. A little nervous now though, since I haven't had any window obstructions and the car is brand new, I'm wondering if I will have to deal with this little window irritant always cropping up.
Old Jun 29, 2014 | 07:44 PM
the most common cause is a low or disconnected battery. the xk and xj have issues with the battery draining when parked. it wouldnt surprise me if the f-type has similar issues. i havent received my car yet so i dont know first hand though.
Old Jun 30, 2014 | 01:51 PM
F-typical's Avatar
There may be a reason that Jaguar sell a trickle charger...
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
DEklof
Sep 8, 2015 05:28 PM
