Winter Storage
Old Oct 28, 2020 | 11:55 AM
richled's Avatar
Default Winter Storage
Hi all,
Hope you all had as productive a summer ripping up the backroads as I have. This will be my first winter with the car. I was hoping to pick your brains regarding storage.
1) Are there specific merits to storing the car in a heated garage versus unheated?
2) I am changing the oil and putting a full tank of gas in the car before storing it for 5 months. Besides using a trickle charger and a good cover, is there anything else I should be considering before storing the car for the winter?
3) Questions I need to be asking the storage provider?
4) Are tire flat spots a real concern?
5) I've been told to open up a bag of charcoal briquets to keep in the trunk to absorb moisture. Has anyone heard of this?
Your input is greatly appreciated.
Cheers,
richled
Popular Reply
Oct 28, 2020, 02:44 PM
RickyJay52's Avatar
RickyJay52
Not to be a wisea$$—there are others here who maintain that mantle with pride and joy—but here is my solution to winter storage:
Old Oct 28, 2020 | 12:43 PM
Rondog's Avatar
I have been "Winter Storing" my cars for over 25 years now. When I first started I did not have a heated garage. SO I purchased a "Car Bubble" One that you park your car on, zip it up, turn on a little fan that inflates the bubble. I felt this kept animals (mice) from getting to the car but also kept air moving so no condensation could build up under the car. I also laid a plastic sheet down then put cardboard down on top of it. I then set the bubble on top of it. ( I know it was overkill !)
Now I have a "Heated" garage with a dehumidifier. I keep the temperature at 58 degrees. Again I laid down a plastic sheet, then put outdoor carpeting over top of that. After cleaning & waxing and making sure the gas tank is full, I put on my car cover, gas stabilizer in the tank, pump all the tires to 45 lbs, connect my battery tender, and then for extra protection a put a mouse trap or two near the outside of the car. Have never had any trap upset but I feel better. I would not recommend moth ***** or anything else on the inside of the car. You'll smell it forever! Good Luck
Old Oct 28, 2020 | 01:29 PM
Therock88's Avatar
Not sure I would fill up the tank with gas just to sit. If you do, you need to add a fuel stabilizer (even if you just have a little fuel, you will need to do this). And just air up the tires to 45-50 PSI as suggested...Or park it on something softer than concrete, like a foam pad, or both. Definitely watch for mice...they will destroy wiring.
And a trickle charger/battery maintainer is a must.
DC
Old Oct 28, 2020 | 01:39 PM
Badger79's Avatar
I've followed the following procedure when storing cars/motorcycles in my unheated garage for 20+ years and never had any issues come spring after 5-6 months of storage:
Give it a wash
Change the oil if you can
Top off the tank with ethanol-free premium fuel (if you can find it near you) and add fuel stabilizer
Inflate the tires to ~45 psi
Use a quality battery maintainer
Cover it
Don't touch it or start it until you're ready to bring it out in spring
If you inflate the tires up I wouldn't worry too much about flat spots if it's only sitting 5 months, I've personally never had modern radial tires flat spot from sitting 5-6 months. Some people will tell you to leave the windows cracked a bit too but I've never done it. As for doing anything for mice, setting a mouse trap or two and plugging the tailpipes won't hurt anything. Probably more possibilities for mice to make your car a home if it's stored offsite or in an area that isn't frequented much during storage.
Old Oct 28, 2020 | 01:41 PM
SinF's Avatar
You want to fill up the tank to minimize air volume at the top of the tank. Air = humidity. Less air, less humidity.
Yes, adding fuel stabilizer is a good idea. It is also a good idea to use ethanol-free fuel. I don't know about NS, but where I live Shell 91 is ethanol free.
Heated is better, as there is no issue with freezing. Heated also means potential critters. I would put dryer sheets (or even better mothballs) on top of wheels and inside the car. Critters don't like smell and won't make a nest in your engine bay.
I don't bother with trickle-charging, just disconnect +ve terminal, wrap it in a rubber glove (to make sure it doesn't snap back onto terminal) and leave it there. Careful to make sure not to close the trunk, I tape a cardboard over it to make sure it can't close.
Flat spots are not a concern, there will be some when you get back and they will work out in 100 km of driving. I do add +5PSI for each tire to minimize this.
Make sure your car cover is breathable, the last thing you want is to have it trap humidity.
Old Oct 28, 2020 | 01:56 PM
mja xkr's Avatar
Default winter storage
have it detailed Mid-November, park it on tire cradles, plug in the battery tender, cover it, set garage temp to 56, and wait for the snow to melt !!!
Old Oct 28, 2020 | 02:44 PM
RickyJay52's Avatar
Old Oct 28, 2020 | 02:53 PM
supersportmtl's Avatar
I'd change the oil in the spring if you don't have a constant storage temperature.
Old Oct 28, 2020 | 03:59 PM
zach05855's Avatar
Heated Garage, use the sticky pads instead of traps as they catch the insect too. and all of the above. I keep my tank as low as possible with stabilizer, then in spring fill up. Use an ethanol free fuel....https://www.pure-gas.org/
All Canada: Shell V-Power 91, Canadian Tire 91, Esso 91
Atlantic Canada: Irving Fuels premium
Western Canada: CO-OP premium
Newfoundland, Nova Scotia, Prince Edward Island: all unleaded gas
Ontario: Costco 91
British Columbia: Chevron 94
Old Oct 29, 2020 | 12:47 AM
19FRG's Avatar
Luckily Kansas city winters have enough gap time between snows i cant ever recall not being able to drive it at least once a week.. some years we get very little snow.
Old Oct 29, 2020 | 01:12 AM
OzXFR's Avatar
I feel sorry for you mob in the northern USA, Canada, Europe etc.
I have never needed to vaguely consider the possibility of not driving let alone storing my car in/for winter, such a thing is unheard of here in Adelaide.
As I have said many times before I have never seen falling snow in my entire life, 65+ years now!
Old Oct 29, 2020 | 06:28 AM
gg2684's Avatar
Indiana is kind of the same - there are usually enough dry days to get it out a couple times a month and run it to lubricate the seals etc and get some gas through it. I also use those times to wash my others; especially if I've used them in the snow. I have hot and cold water connected to my water softener which makes winter washing manageable. My garage is also heated and I usually put some extra air in the tires and I regularly run fuel system cleaner and of course always do a detail in the spring and one in the fall, but I am struggling with the mouse trap recommendations - do you all get a lot of mice and critters in your garages?
Old Oct 29, 2020 | 06:41 AM
scm's Avatar
scm
Here in southern England I've never seen fires burning out of control - 70 years now. I guess we all have our crosses to bear ...
Time-Pilot
Feb 2, 2020 12:55 PM
Barry_Tucker
Nov 21, 2018 08:14 AM
peterv8
Dec 11, 2017 08:14 PM
briruss3
Oct 30, 2016 06:45 AM
oyster
Dec 27, 2012 12:27 PM
