Winter wheel question!
Old Sep 18, 2025 | 11:05 PM
Slip_Angle's Avatar
Default Winter wheel question!
I purchased a set of winters and decided I better test fit them before the snow comes. Stock summers are 295/30/20 and 255/35/20. The winters are 275/35/19 and 245/40/19 - they fit well in terms of offset and clearing the brakes. However, I did notice in the rear that the gap between the top of the tire and fender is larger than expected. I'm not sure if that's because it was just a test fit on one said of the car? The other side still had the summers on and I lowered the car to see if things were ok.
I've seen other F-Type's that have stock 19s in the same sizes as above and they seem to fit fine. Is it because I had the stock summers on the other side and didn't move the car to settle things?
Old Sep 19, 2025 | 08:03 AM
Slip_Angle's Avatar
Interestingly, the winters are -1% vs the summers in overall diameter. I would have preferred them slightly larger but these were the best fit. When I compare the wheels side by side, the difference isn't much. However, when they go on the car, the gap in the rear is significantly larger. It must be as you say that the suspension hadn't settled and the other side had the summer on.
Hoping the F-Type is decent in winter!
Old Sep 19, 2025 | 08:13 AM
Robtrt8's Avatar
It would be helpful if you added year, trim, motor and whether or not AWD to your signature.
Old Sep 19, 2025 | 08:14 AM
Slip_Angle's Avatar
Ok, will do. Thanks
Old Sep 19, 2025 | 08:16 AM
Robtrt8's Avatar
Also, curious which winters did you buy?
Old Sep 19, 2025 | 08:18 AM
Slip_Angle's Avatar
Michelin Alpin 5s
Old Sep 19, 2025 | 08:22 AM
Robtrt8's Avatar
Nice!
QP7
Jun 28, 2025 08:58 AM
Diorwing
Sep 30, 2021 09:13 AM
amillsmcewan
Jul 17, 2014 07:38 AM
Drb007
Nov 24, 2013 11:11 AM
matl
May 15, 2007 01:22 PM
