Wrench lodged deep within Driver Seat track - Help
Old Nov 18, 2018 | 11:46 AM
jackra_1's Avatar
In my manual it simply has two arrows pointing to each of the lower corners of the control switch panel and implies you lever up from there.It is not that clear.
It simply says "remove panel".
IF you can get the leather cover lifted up it may not help much depending upon what you see with the foam. But you could possible lever the foam away to some extent to see down the side better without worrying about damage to the leather? This is all guesswork.
Old Nov 18, 2018 | 11:50 AM
scm's Avatar
scm
Which F-Type MY has a control panel on the seat?
Old Nov 18, 2018 | 11:51 AM
Rivguy's Avatar
I would try a magnetic pick up with a flexible head. Yes it would stick to the track but also to the wrench which will come along with it. It it easily slipped in it should find it's way out. Don't get a pick up with a head that is too large, the circular ones seem best. Good luck
Old Nov 18, 2018 | 12:01 PM
jackra_1's Avatar
https://www.ebay.com/itm/Front-Left-...QAAOSwPypajYAg
The above Ebay listing for a front seat gives one an idea what the underside of the seat looks like???
Old Nov 18, 2018 | 02:11 PM
mlebofsky's Avatar
Seeing the back of the seat, I've always wondered what the purpose of the groove on the back of the headrest that mates with the car's hook serves?
Old Nov 18, 2018 | 04:27 PM
WJV's Avatar
WJV
Ended up cutting a torx bit in half and buying the smallest rachet i could find to get those front seat bolts out. It was slow progress but patience prevailed and not only did I get the seat out but I got other wrench out that was wedged in the rail. Would have never been able to get it out w/o removing the seat. Thanks again for all the input, glad this nightmare is over.
Old Nov 18, 2018 | 04:40 PM
jackra_1's Avatar
I like good ending!
Old Nov 18, 2018 | 04:52 PM
  #28
OzXFR's Avatar
As far as I can tell that groove is simply to allow the seat back to go all the way back without fouling on the hook.
Old Nov 18, 2018 | 05:51 PM
Carbuff2's Avatar
So, what purpose does the hook serve?
(Don't tell me its sole purpose is to fit in the seat-back's groove!)
Old Nov 18, 2018 | 06:02 PM
  #30
Unhingd's Avatar
I use the hook on the passenger side for the dry cleaning. If you push the seat all the way back, you can even iron wrinkled shirts.
Old Nov 18, 2018 | 06:37 PM
  #31
OzXFR's Avatar
Yep, it's a clothes hook.
I sometimes hang my "Jaguar" jacket on it.
Old Nov 18, 2018 | 06:56 PM
  #32
mlebofsky's Avatar
I assume people typically have a few inches between the seat back and the hook (typical seat positioning)?
Old Nov 18, 2018 | 07:18 PM
  #33
Carbuff2's Avatar
Hmmm...we may need to rethink our practice of setting seat MEMORY 3 to be all the way up & back (for easy entry).
Can't have creases in our shirts. What would the paparazzi think?
Old Nov 18, 2018 | 07:31 PM
  #34
OzXFR's Avatar
Yep, per the Jaguar "Good To Be Bad" ad all proper baddies are immaculately dressed with not a crease in sight:
This ad is why my numberplate is GD2BBAD.
Old Nov 19, 2018 | 03:08 AM
  #35
Unhingd's Avatar
I'd guess for most folks there's less than an inch remaining.
+1. MEM 3 for my passenger seat is full forward specifically for the purpose of using that hook.
Old Nov 19, 2018 | 03:16 AM
  #36
scm's Avatar
scm
My MEM 3 is with the passenger mirror dipped slightly for reversing - the auto dip goes down much too far and isn't adjustable.
Old Nov 19, 2018 | 04:44 AM
  #37
Hayabusa's Avatar
Followed this saga, imagining if I had my family fortune and a wrench or 2 jamming my seat track. What would I do? As usual, experienced forum members to the rescue with insights and suggestions to help save the day. Bravo!
As information flows the topic shifts based on an E-bay listing. The Hook and the Groove...add a video I've viewed many times and was happy to watch again.
Best practice seat positioning for transporting haberdashery. My cat is hibernating for the winter (snow came last week with the requisite salt and pea gravel), however, I now have reason besides pampering and checking the C-Tek to play with her.
I will now be able to transport dry cleaning and a jacket appropriately behind the passenger seat. I know I have hooks, never noticed the grooves. Love the detail and I love this place!
Very pleased to see the OP's outcome. A Thanksgiving story for the dinner table in Augusta later this week.
Old Nov 19, 2018 | 07:42 AM
  #38
Unhingd's Avatar
I thought of that too Lance (I have one of those gadgets), but then I thought "the seat runners are bound to be iron/steel (not alu) so the magnet will just get stuck on them and not grip the wrench at all".
Still worth a try though!
I found that when the item is near a massive metal part you can slide the magnet in a parallel direction down that piece and still pick up smaller metallic items (ferrous, of course).
Old Nov 19, 2018 | 11:19 AM
  #39
sov211's Avatar
None. Those comments are all based on the seat configuration of an XJ and have, unfortunately, very little relevance to the situation with an F-Type.
Old Nov 19, 2018 | 11:30 AM
  #40
jackra_1's Avatar
What a useless comment!
I was trying to help by showing an example of what the track COULD look like and I pointed that out since I felt the best way of tackling the issue at hand was to take out the bolts holding the tracks. Where are your helpful comments?
styper2003
Mar 31, 2020 05:08 PM
Griff79
US Central
May 9, 2017 09:20 AM
gbmtkj
Mar 14, 2015 03:29 PM
DittoGlen
Oct 20, 2010 08:09 PM
Runitup10
May 31, 2010 09:13 AM
