You must paddle (not auto) shift when in dynamic sport mode?
Old Sep 23, 2014 | 08:03 PM
lunagry's Avatar
Banned
Default You must paddle (not auto) shift when in dynamic sport mode?
Possible FYI for F-Type owners wishing to make sure they do not needlessly damage their car -- I think I read this in the manual.
If you're in sport mode shifting but not in dynamic mode, and you haven't touched the paddle shifters, then the transmission will go through the shifts automatically without you having to do anything but hit the gas and brakes.
Same thing if you're in drive mode shifting and in dynamic mode.
But if you're in sport mode shifting and in dynamic mode, then the transmission won't automatically shift for you. You need to hit the paddles to shift. So if you're in this mode and you floor it, but you do not touch the paddle shifters, it's not good for the engine because you're providing too much power in the wrong gear.
Not sure if the above is right but I think it's what the manual says.
Old Sep 23, 2014 | 08:13 PM
Stohlen's Avatar
This is not true. The engine is not being hurt by this. The rev. limiter prevents engine damage, that's the whole point.
Old Sep 23, 2014 | 08:18 PM
lunagry's Avatar
Banned
Thanks. Let me see if I can find the page in the manual where I read the above (about the transmission not shifting up if you're in sport dynamic mode).
I'm just trying to make sure I don't do anything to create maintenance / service issues. I've had too many sports cars go from my fantasy cars to my nightmare because they weren't reliable.
Old Sep 23, 2014 | 09:14 PM
aJAGMan's Avatar
Banned
Yes and No.
Yes, Sport mode + Dynamic mode + Paddles results in a true Manual Shift mode. Transmission will not upshift or downshift (automatically) unless manually directed to do so by use of the paddles.
No, you are not likely to blow up your engine. the rev-limiter will simply cut fuel to the engine if you run RPM's into the redline. I also believe that if you repeated hit the rev-limiter while in this setting, the electronics will revert the settings to engage automatic shifts.
Old Sep 23, 2014 | 09:21 PM
shift's Avatar
just don't downshift in the wrong gear
Old Sep 24, 2014 | 06:05 AM
drgek's Avatar
Originally Posted by aJAGMan
Yes and No.
It will downshift automatically when coming to a stop, but won't kick down automatically if you floor it.
Old Sep 24, 2014 | 12:50 PM
F-typical's Avatar
The rev limiter won't protect you if you put in too many downshifts at high rpm...
Forcedair1
Sep 8, 2025 01:57 PM
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
Clamdigger
Sep 12, 2015 03:43 PM
