68 jag 4HA salisbury diff
Old Jan 12, 2014 | 06:24 PM
Sterlingcousins's Avatar
Default 68 jag 4HA salisbury diff
Have 39 chev sedan with jag diff 3:31 ratio. found 2:88 gear set
and need LSD carrier. or any ideas to get gears to work?
Old Jan 12, 2014 | 07:17 PM
motorcarman's Avatar
If the 3.31 diff is from an 'E' type then you already have a Limited Slip.
A 2.88 diff from XJ-S will also already be LSD.
Sedans are hit or miss as far as LSD is concerned.
bob gauff
Old Jan 13, 2014 | 12:11 PM
Default 68 jag 4ha
I have a locking diff with the 3:31 but to install 2:88 the offset is different so I am in need of a case.
will the LSD case for the 2:88 work in this 4HA housing and are there any available?
Old Jan 13, 2014 | 08:21 PM
Just get a 1980s vintage XJ-S diff and install it in your suspension 'cage'.
They should all be 2.88 LSD.
bob gauff
Old Jan 13, 2014 | 11:21 PM
I'll keep looking for a case but now also looking for a diff.
hoping all the bolt holes are the same and axles would be the same.
thanks for the idea
Old Jan 14, 2014 | 07:56 AM
If you have an 'E' Type diff assy then the axles and lower control arms are shorter than an XJ-S.
The diff cases will fit. You might want to use the later brake calipers.
bob gauff
FrickenJag
Jun 16, 2025 02:15 PM
Doovoe
Sep 8, 2015 05:42 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
MrMellor
Sep 7, 2015 10:22 AM
1100me
Sep 7, 2015 06:26 AM
