attachments for shop press for removing/installing suspension bushings?
Old Feb 24, 2015 | 07:04 AM
hunter34's Avatar
Default attachments for shop press for removing/installing suspension bushings?
I've got a 12-ton shop press from Harbor Freight. I've got a new set of bushings for the rear control arm on my 2004 XJR.
Where do you find the accessories for driving out the old bushings and driving in the new bushings? (What are they called might be a good start).
I'm very mechanically inclined, and I've changed bushings before, but I just happened to have a steel pipe that was the exact size I needed last time. This time I don't and I need to locate something.
Old Feb 24, 2015 | 04:00 PM
Gus's Avatar
Gus
You can get them at Harbor Freight you just need to make sure you get the right set.
Old Feb 24, 2015 | 08:21 PM
hunter34's Avatar
I was there in the store today, but the two sets that they had in stock didn't fit. (I brought the bushings in to test fit.)
The bigger bushing needs an O.D. 56mm (2 7/32) and an I.D. > 49mm (1 15/16)
The smaller bushing needs an O.D. 47mm (1 27/32) and an I.D. > 41mm (1 5/8)
What are these things called? Receivers? Drifts? Press gadgets?
Old Feb 24, 2015 | 08:52 PM
Gus's Avatar
Gus
Have you looked at sears tools on line?
Old Feb 24, 2015 | 09:07 PM
Gus's Avatar
Gus
I went to the HorborFreight webpage and could not find the metric set I thought they once had. Disappointing!
hafren
23
Jan 3, 2025 11:26 AM
dsnyder586
Dec 29, 2024 07:39 PM
trosty
26
Dec 18, 2022 06:40 PM
trosty
Dec 17, 2021 07:41 AM
tberg
Sep 7, 2015 07:32 AM
