Car vibrating over 40 miles an hour
Old May 6, 2022 | 09:21 AM
Mill's Avatar
Default Car vibrating over 40 miles an hour
Car vibrating from prop shaft around 40 miles an hour.
hi wonder if anybody could help. We have had the seals replaced on the differential, on my fathers Jaguar XJ sovereign V6 2008.
The mechanic has refitted the differential and when test driving it there seems to be a vibration around 40 miles an hour. He has re-loosen the prop shaft and then re-tightened them but this still seems to are to make no difference.. Wondered if anybody could help with this question. Is it the
Old May 7, 2022 | 08:47 AM
guy's Avatar
guy
“refitted the differential”. That may be the issue, right there. OEM seals and bearings used? New bolts and bushings?
Old May 7, 2022 | 09:11 AM
Thermo's Avatar
Veteran: Navy
Mill, this is a common issue with the X-Types. We have found that if you put some termaline grease into the prop shaft bearing, it will cut down on the noise and shaking. ubt, in the end, you are going to need a new prop shaft bearing.
makjohannesson
Jun 22, 2015 06:25 PM
RichardPhuket
Nov 24, 2014 11:19 PM
hawianjim
Oct 3, 2013 06:29 AM
Stickman
Mar 20, 2013 01:45 PM
ktag
Jun 20, 2011 10:18 AM
