Code
Old Aug 14, 2008 | 09:01 PM
Default RE: Code
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Hey Darel welcome to the site..........can't help but no doubt someone out there can.
I'll move it to general tech help for better assisitance.
Try the Faq section for codes
Good luck
Jim
Old Aug 14, 2008 | 11:05 PM
Jag4.0's Avatar
Default RE: Code
Darel-
When you post a question of this nature, you REALLY need to add the year and model of your car in question. Jag varied the location of modules and sensors and system "logic" throughout the years (even for cars that were essentially the same models such as 88-94 XJ6). In case you're dealing with a 88-94 XJ6, XJS or similar, I can tell you that code 69 the "Drive/Neutral switch input circuit". The ECM looks for an input from this switch and adjusts idle speed accordingly (the idle speed in D is lower than N, apparently). The ECM gives a code 69 if gear selector is not in P or N when started. This code can also be caused by a low batt., gearshift cable misadjusted, transmission switch misadjusted, etc.
Good Luck,
Greg
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
